All nodes not populating in Polyglot V3
EricBarish
Looking at the node values more closely, I have found the following:
This is the status of the nodes in the ISY dashboard for  polyglot  V3  webcontrol832  ver 1.02
All 29 nodes added to the json_node_names have been created, showing up in the  dashboard under nodes and in the ISY control panel
OP, TS nodes are populating with the data from the CAI webcontrol
HS1 and all IP nodes are not being populated with the data from Cai webcontrol  0 for all items in value variable
Have not checked the AIP  nodes
This data is being populated in the old nodelink
Not sure if this was working in the earlier versions only looked at the ts values and they worked
I am so sorry for the issues you are having. I do not have a humidity sensor to test off of. It is being created based on similar config as temp sensors. I will have more to go on once I see your logs.
IP values were working correctly however in my current set up involving 3 WC boards, none use IP.
I will hook up my 4th board for testing those values.
In the mean time, do me a favor. in the plugin for WebControl832 in PGx, set the plugin logging for "info" then stop the plugin, wait a few seconds and restart it. Give me about 5 minutes of data then turn the logging back to where it was, download the package and PM me.
Also, please supply in the same email your json.
I will look into this, again I apologize.
-Tim
Tim
 Thats how development goes.  No concerns, still using nodlink in programs , until this plugin is completely debugged.  Will get your data for the log,  here is the json input string.
{"aip1": "AIP 1", "aip2": "AIP 2", "aip3": "AIP 3", "hs1": "humidity", "ip1": "IP 1 Fire Alarm", "ip2": "IP 2", "ip3": "IP 3", "ip4": "IP 4 Co2 System", "ip5": "IP 5", "ip6": "IP 6", "ip7": "IP 7", "ip8": "IP 8",  "op1": "OP 1 Basement Damper", "op2": "OP 2 Attic Damper", "op3": "OP 3 Water Cutoff", "op4": "OP 4", "op5": "OP 5", "op6": "OP 6", "op7": "OP 7", "op8": "OP 8", "ts1": "Temp 1 Second Floor", "ts2": "Temp 2 Basement", "ts3": "Temp 3 Attic", "ts4": "Temp 4 First Floor", "ts5": "Temp 5 Outside", "ts6": "Temp 6", "ts7": "Temp 7 ", "ts8": "Temp 8 "}
 Eric
Hey Eric,
Cool! I figured hs would work but not having a way to test, you really helped me out. Thanks for confirming. I can confirm AIP, OP, TS and Var are working on my end as well so you should be good to go.
Appreciate your time and patience.
Happy Holidays!
      378.5k
