plugin incorrectly shows iphones offline after a few hours
I have the MAC addresses of 2 iphones configured in unifipresence. Starting several weeks ago these MAC addresses started going offline a few hours after I start the plugin. I'm not changing The wifi network on the phones. The log looks like the phones just left the network normally but they are still on the network and functioning normally. If I restart the plugin they show online again. Has anyone else seen this problem? Here's an excerpt from the debug log. They go offline at 23:02:46
2024-12-30 23:02:31.280 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2024-12-30 23:02:31.280 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2024-12-30 23:02:31.281 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2024-12-30 23:02:31.281 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: controller:UnifiCtrl No change in ST's value
2024-12-30 23:02:31.332 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: 08e68991dc26:08e68991dc26 No change in GV1's value
2024-12-30 23:02:31.351 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: 141ba02a0601:141ba02a0601 No change in GV1's value
2024-12-30 23:02:31.368 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: 6c1f8aaa354c:6c1f8aaa354c No change in GV1's value
2024-12-30 23:02:31.385 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: c82add87d78d:c82add87d78d No change in GV1's value
2024-12-30 23:02:31.402 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: 0298647559fe:0298647559fe No change in GV1's value
2024-12-30 23:02:31.419 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: 66ad0b5f3510:66ad0b5f3510 No change in GV1's value
2024-12-30 23:02:31.436 Thread-616 (poll) udi_interface.node DEBUG node:setDriver: daf3559f989e:daf3559f989e No change in GV1's value
2024-12-30 23:02:45.143 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2024-12-30 23:02:45.143 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2024-12-30 23:02:45.143 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2024-12-30 23:02:45.143 Thread-617 (poll) udi_interface DEBUG unifi_poly:heartbeat: heartbeat: hb=1
2024-12-30 23:02:45.152 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'command': [{'address': 'controller', 'cmd': 'DOF'}]}
2024-12-30 23:02:45.179 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message command
2024-12-30 23:02:45.180 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2024-12-30 23:02:45.180 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS command message {'address': 'controller', 'success': True} from Polyglot
2024-12-30 23:02:46.288 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2024-12-30 23:02:46.288 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2024-12-30 23:02:46.288 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2024-12-30 23:02:46.288 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: controller:UnifiCtrl No change in ST's value
2024-12-30 23:02:46.293 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: 08e68991dc26:08e68991dc26 No change in GV1's value
2024-12-30 23:02:46.293 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.297 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: 141ba02a0601:141ba02a0601 Reporting set GV1 to 0 to Polyglot
2024-12-30 23:02:46.297 Thread-618 (poll) udi_interface.node DEBUG node:reportDriver: Updating value to 0
2024-12-30 23:02:46.297 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.298 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'address': '141ba02a0601', 'driver': 'GV1', 'value': '0', 'uom': 2, 'text': None}]}
2024-12-30 23:02:46.301 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: 6c1f8aaa354c:6c1f8aaa354c Reporting set GV1 to 0 to Polyglot
2024-12-30 23:02:46.301 Thread-618 (poll) udi_interface.node DEBUG node:reportDriver: Updating value to 0
2024-12-30 23:02:46.301 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.305 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: c82add87d78d:c82add87d78d No change in GV1's value
2024-12-30 23:02:46.305 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.309 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: 0298647559fe:0298647559fe No change in GV1's value
2024-12-30 23:02:46.309 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'address': '6c1f8aaa354c', 'driver': 'GV1', 'value': '0', 'uom': 2, 'text': None}]}
2024-12-30 23:02:46.309 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.313 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: 66ad0b5f3510:66ad0b5f3510 No change in GV1's value
2024-12-30 23:02:46.313 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.317 Thread-618 (poll) udi_interface.node DEBUG node:setDriver: daf3559f989e:daf3559f989e No change in GV1's value
2024-12-30 23:02:46.317 Thread-618 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:02:46.327 MQTT udi_interface.interface INFO interface:_message: Successfully set 141ba02a0601 :: GV1 to 0 UOM 2
2024-12-30 23:02:46.419 MQTT udi_interface.interface INFO interface:_message: Successfully set 6c1f8aaa354c :: GV1 to 0 UOM 2
2024-12-30 23:03:01.289 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2024-12-30 23:03:01.289 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2024-12-30 23:03:01.289 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2024-12-30 23:03:01.290 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: controller:UnifiCtrl No change in ST's value
2024-12-30 23:03:01.294 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: 08e68991dc26:08e68991dc26 No change in GV1's value
2024-12-30 23:03:01.295 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.298 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: 141ba02a0601:141ba02a0601 No change in GV1's value
2024-12-30 23:03:01.298 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.302 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: 6c1f8aaa354c:6c1f8aaa354c No change in GV1's value
2024-12-30 23:03:01.302 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.306 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: c82add87d78d:c82add87d78d No change in GV1's value
2024-12-30 23:03:01.306 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.310 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: 0298647559fe:0298647559fe No change in GV1's value
2024-12-30 23:03:01.310 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.314 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: 66ad0b5f3510:66ad0b5f3510 No change in GV1's value
2024-12-30 23:03:01.314 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
2024-12-30 23:03:01.318 Thread-619 (poll) udi_interface.node DEBUG node:setDriver: daf3559f989e:daf3559f989e No change in GV1's value
2024-12-30 23:03:01.318 Thread-619 (poll) udi_interface INFO unifi_poly:update: update: 0
