Trouble setting up
Go to solution Solved by SHM,
I have installed the new NS and installed in PG3 (latest firmware).  Restarted the NS and ran authenticate, which took me to Tesla.com where I signed in (for my 2017 Model S).  NS then returned 4 nodes:  Charging info (with 20 sub nodes, most showing data), Climate info (17 sub nodes, most showing data), Tesla EV info (5 sub nodes) and Merrick Tesla (18 sub nodes, mose showing data).  On the AC, only 2 nodes show up (see attached) with no data.  Attaching the log and some screen shots.  Not sure where to go from here.
udiTeslaEV2_1-4-2025_12726_PM.zipFetching info...
have you tried restarting the nodeserver in the PG3x panel?  also:  try restarting your admin console, maybe even need to delete your java cache.
This might sound silly, but the region is set to NA?  Does it need to have US set?  The "Connected to Tesla Cloud" reading Disconnected is where I would start.  That looks like the node server isn't logged into Tesla to get the data from your car.  the "Controller Connected" displaying "Connected" might only be the node server to your AC?
Problem solved!  I eliminated the "token" from the older node version and all works.
      376.9k
