January 5, 2025Jan 5 Any guess on why some yolink devices are missing the name in the node info (xray and rest/status) and others are not. For example, this leak sensor: <properties> <property name="Sensor Temperature" uom="17" formatted="72°F" value="72" id="CLITEMP"/> <property name="" uom="25" formatted="Dry" value="0" id="GV0"/> <property name="" uom="25" formatted="High" value="4" id="GV1"/> <property name="" uom="25" formatted="DON/DOF" value="0" id="GV2"/> <property name="Connection State" uom="25" formatted="Online" value="0" id="GV20"/> <property name="Nodeserver Status" uom="25" formatted="Connected" value="1" id="ST"/> </properties> It is not a problem with the admin console because that has all the names right: This Temp Humidity sensor has all the names filled in: <properties> <property name="Battery Level" uom="25" formatted="High" value="4" id="BATLVL"/> <property name="Current Rel Humidity (%)" prec="1" uom="51" formatted="43.3%" value="433" id="CLIHUM"/> <property name="Sensor Temperature" prec="1" uom="17" formatted="73.2°F" value="732" id="CLITEMP"/> <property name="Low Temp Alarm" uom="25" formatted="Normal" value="0" id="GV1"/> <property name="Low Temp Limit" prec="1" uom="17" formatted="64.4°F" value="644" id="GV10"/> <property name="High Temp Limit" uom="17" formatted="95°F" value="95" id="GV11"/> <property name="Low Humidity Limit" uom="51" formatted="0%" value="0" id="GV12"/> <property name="High Humidity Limit" uom="51" formatted="100%" value="100" id="GV13"/> <property name="High Temp Alarm" uom="25" formatted="Normal" value="0" id="GV2"/> <property name="Connection State" uom="25" formatted="Online" value="0" id="GV20"/> <property name="Low Humidity Alarm" uom="25" formatted="Normal" value="0" id="GV4"/> <property name="High Humidity Alarm" uom="25" formatted="Normal" value="0" id="GV5"/> <property name="Battery Alarm" uom="25" formatted="Normal" value="0" id="GV7"/> <property name="Alarm triggered" uom="25" formatted="Normal" value="0" id="GV8"/> <property name="Command Setting" uom="25" formatted="DON/DOF" value="0" id="GV9"/> <property name="Nodeserver Status" uom="25" formatted="Connected" value="1" id="ST"/> </properties> I have the latest everything and restarted everything. Andy
January 5, 2025Jan 5 i’ll try to see if can find something in the node def setup files. there may be something missing
January 6, 2025Jan 6 I found the difference - I use global naming for some of the common parameters - these do not seem to propagate to the REST - but works with AC. Not sure if global naming is supported but it works with AC Maybe ask UDI if it is a bug or if I cannot use global naming I'll fix it if global naming is not supported (but it is some extra work (and a lot of testing) -
January 8, 2025Jan 8 i believe it is real. it is not the nls file is parsed. i am using global definition for some common nodes. it seems the rest does not pick this
January 8, 2025Jan 8 2 minutes ago, Panda88 said: i believe it is real. it is not the nls file is parsed. i am using global definition for some common nodes. it seems the rest does not pick this Yes I've seen that. But my question is - Were you able to reproduce the problem?
January 8, 2025Jan 8 Author This was the response I received from the ticket: Chris Jahn replied 3 hours ago Hi Andy, We are in the process of fixing and enhancing the NLS capabilities for node servers. Problems like this are fixed in the new code.
