EISY NVMe SSD configuration failure.
Added a 500GB NVMe drive to my EISY and was following the instructions here: https://developer.isy.io/blog/eisy-way
I ran the:       sudo fl.ops setup.nvme.boot   command.
The process fails on this step:  zpool attach -f zudi /dev/mmcsd0p3 /dev/nvd0p2
with the following error:    cannot attach /dev/nvd0p2 to /dev/mmcsd0p3: can only attach to mirrors and top-level disks
I tried it twice, once trying to create a 150GB extra partition, the second time not adding any partition.  The results were the same each way.
My udx Version is   : 3.5.7_4
nvmecontrol devlist  shows the following:
 nvme0: CT500P310SSD8
    nvme0ns1 (476940MB)
Any ideas what else I can try?
I'm sure some here have experience with the process, but not sure about resolving. The best bet on this more advanced process with the eisy might be best handled directly with UDI via a support ticket.
Please be sure to post back the resolution so it might help others if they run into this situation.
