Issues setting up in Windows
I had a PC issue and had to redo the PC that was running nodelink.  I never had any issues with nodelink and have 4 nodes on it and bunches of programs all integrated with those nodes.
IOguy seems to have stopped supporting it.  I copied my entire nodelink folder to a backup prior to reinstalling windows, but can't get it working after copying back to the redone pc.  I was able to get a really old version of nodelink running but it is not linking to ISY properly.  When I try to run the newer versions of nodelink I just get a flash of a cmd screen.  I installed the latest .net from microsoft (.net 9.0 sdk).
Anyone who could help me here with info on how to get this working I would much appreciate.  I really don't want to go through the maze of programs and figure out how to redo it all and then debug it and so on.
Below is what I get running the super old version of nodelink. It does link to the targets (DSC alarm panel, several webcontrol boards and the date program), but not to ISY.
And I am using Polisy
2025-01-12 14:30:45 - ISY NodeLink Server v0.9.34 started
2025-01-12 14:30:45 - OS: Microsoft Windows NT 10.0.19045.0
2025-01-12 14:30:45 - Web config server started (http://192.168.1.71:8090)
2025-01-12 14:30:47 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/EDITOR/I_EDIT.XML)
2025-01-12 14:30:47 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/NODEDEF/I_NDEFS.XML)
2025-01-12 14:30:47 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/NLS/EN_US.TXT)
2025-01-12 14:30:47 - DSC: Repeater started on port 4025 [dsc1]
2025-01-12 14:30:47 - DSC: Connected to 192.168.2.141 [dsc1]
2025-01-12 14:30:47 - ISY Error: Web Error - NotFound (climate)
2025-01-12 14:30:47 - DSC: 5053CD[C][L] [dsc1]
2025-01-12 14:30:47 - DSC: 505 - Login Interaction (Password Requested) [dsc1]
2025-01-12 14:30:47 - DSC: EVL User Login - Password Sent [dsc1]
2025-01-12 14:30:47 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1]
2025-01-12 14:30:47 - DSC: 500 - Command Acknowledge (005) [dsc1]
2025-01-12 14:30:47 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1]
2025-01-12 14:30:47 - DSC: Status Request Sent [dsc1]
2025-01-12 14:30:47 - DSC: Data Sent - 00191 [dsc1]
2025-01-12 14:30:47 - DSC TCP: Polling DSC [dsc1]
2025-01-12 14:30:47 - DSC: 50000126[C][L]61000128[C][L]60900231[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]60900736[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1]
2025-01-12 14:30:47 - DSC: 500 - Command Acknowledge (001) [dsc1]
Edited by apostolakisl
