Brand New EISY appear DOA
I purchased a new Eisy several months ago and I am just getting around to setting it up.  I followed the instructions, but it does not connect to my router either wired or wireless, so no IP address. No activity on the ethernet port lights when cable plugged in.  Does not appear on the  bluetooth list when trying to connect wireless.  The power button either shows a red light (I assume this means turned off) or blue light (I assume turned on).  There appears to be no other activity on the Eisy. Is there supposed to be some activity with the power light or something to tell if it is actually alive.  Tried a factory reset and reboot but no sign of life.  Was going to try to see if the actual manufacturer had a manual but I don't know who make it.  Any help greatly appreciated.
Solved by Techman
The device itself is a MeLE Mini PC.
So did you look at your router's device table and it doesn't appear? Have you tried more than one network cable and router port?
@bobbob21
Try replacing the ethernet cable between the router and the eisy. Also try removing power from the eisy for about 15 seconds.
Edited by Techman
Well, it turns out that my brand-new cable was defective.  Replaced the cable and now it is working.  Thanks for the help all.
