Polisy will not boot.
Recently I was prompted that there was an update.  I found this a bit strange given the platform is no longer supported.  Logged into the box as I waned to see what the specific update was.  It turned out to be and IOS update.  Seemed odds but I went ahead and executed the update via the console.  All seemed good but then I discovered that the upgrade failed and it was still showing that an update was available.  I reviewed the log and found that the the install was failing mid way.
I decided to reboot the system to  see if that would clear it up; no luck.  The system now only powers on with all three lights initially on and then the second and third turn off.  The far left stays on solid, never flashes and there is no beep indicating that it has booted.
At this stage the system is powered on but unresponsive and not responsive to SSH and ping attempts.
I feel I have a brick on my hands but I was hoping there might be some light at the end of the tunnel.   Any Help/suggestions would be great.
Cheers,
Ken.
Solved by Beaker
My polisy bricked also after the upgrade.  I've been  working with support (Michel) to try and get it back to life.  You should file a support ticket.
Thank you bob123 and Paulbates.  Have a response from Michel and moving forward with a fresh SSD image.  Will also be adding a new SSD for good measure.
Cheers,
Ken.
