New version available! But wait…
UD Mobile iOS update finally released, but, um, see pic. I’m hanging on for the ride! Wheeee!
Edited by 737simguy
Solved by Javi
Yes, I am on 5.9.1 and it wants me to update to 5.8.4. I’m sure it’s just a simple bug, just struck me as humorous ;-)
The notification is generated from the box itself, so there is an update.  The app does not know the version, it pulls the version from a server, but looks like server was not updated with the current new version.
Even though I am already on firmware 5.9.1, I get the same notification.  it appears both in UD Mobile and the Administrative console. Just an FYI.
I went ahead and did the “Update Packages” from within the Admin Console and it did update something, now all looks normal again and still on 5.9.1.
I also did a sync in the UD Mobile after the update. It shows an error as in the attached pic but everything seems to work fine. I have no Matter devices yet.
@737simguy interesting that it had another update to process. Not sure about this error.
What do you see when you go to this page:  https://eisy.local:8443/WEB/pkg.upgrade.htm  (maybe use the eisy IP address if it doesn't resolve. If it gives you an alert/warning about it not being safe click to proceed since it's a local device it's okay to proceed.)
Looking for results: "No packages need upgrading."
In admin console is the Matter option "ON"? If you don't have any Matter devices leave it "OFF". Then run a sync again see if you get any errors. Be sure to fully close the app while you're working in Admin Console then reload the app. What app version are you running?
The UDM Synch error is fixed in the next app update.  It can be ignored until that time as it is only stating there are no matter devices.
Okay I went to that page using the IP address and got the "No packages need upgrading" return.
App version is 1.2.2
All good here. Thanks for the response!
