Trying to Change Jason string in config
Trying to Change a node name using the Jason string in config setup.
Here is the part I changed :
, "ts5": "Temp 5 Outside", "ts6": "Temp 6  Aquarium",
changed "tsb6": "Temp 6"   to "tsb6": "Temp6 Aquarium"
saved changes, waited a period of time and then restarted
Change does not showup for the name under nodes
Eric
@EricBarish, Are you running non production or production?
What version?
Please copy and paste your json exactly as it appears in PG3x.
Are those the only two that do not change or are there others that do change but just these two do not?
Edit:
Also, please PM me your log from WebControl832 from PG3x.
-Tim
Edited by TJF1960
additional request
Requested info sent directly to TJF.  When we find a solution will post here.
Fixed renaming nodes on the fly in v1.0.6
