Posted March 18Mar 18 A new TeslaEVstream node server has been added to the beta (non-production) store for testing It uses the new tesla official streaming interface allowing data to update when data changes on the EV - NO NEED TO POLL DATA. This node will replace the existing udiTeslaEV2 node going forward. If more or different data is desired take a look at https://developer.tesla.com/docs/fleet-api/fleet-telemetry/available-data to see what data is available (long list) and let me know. I can try to add it during this beta release Short Poll generates a hear beat Long Poll updates the state of the car (Online, Offline , asleep etc). It also checks if tokens need to be updated None of the Poll gets data from the EV - the EV streams data as they change (max rate is set to 60 sec for most settings). To use the node server, one must install an electronic key on the car On your mobile device open https://tesla.com/_ak/my.isy.io. It should open the tesla app where you can approve the key-install - Older EVs may not support the virtual key. Note, currently only supports NA EVs Additionally, one must open external access on the eISY/Polisy. got to https://my.isy.io/index.htm and log in Select PG3->Remote Connections on the eISY/Polisy Make sure that Remote Connection is ACTIVE To validate if the connection works, there is a TEST button/command on the main page on the node (result shown in the last field in the main page). Edited March 18Mar 18 by Panda88
April 4Apr 4 Hi Panda, Quick q for u. I think I purchased the previous version of the node. Would I eventually be able to apply my payment to the new version? It's a trial for now. Edited April 4Apr 4 by Traditore
April 4Apr 4 Author I think this is a question for UDI - They are in charge of the payment system. Yes - we are testing how reliable the new approach is - data is running through UDI servers - I think we are getting close, so there should be an official release soon The new node has some real benefits - i.e. it will use less battery of the car, as it only updates data when there is a need. There are also a few more info fields and support for sentry mode.
April 5Apr 5 Ok, thank you for getting back to me. We'll see what happens when it's time to purchase. By the way, the PSI readings are wrongs. It seems the decimal is misplace. I'm getting 3.15 PSI instead of 31.5.
April 5Apr 5 Author I think you are correct that something is wrong - It is a raw number from the API - it may be reporting in BAR and not PSI- so you actually need to multiply the number by 14.5 I believe - I'll fix it Edited April 5Apr 5 by Panda88
April 5Apr 5 That makes more sense. Otherwise, my tire pressure would be 10 PSI too low. Should be about 42.
