Bathroom programs stopped working
Hello,
I have a few programs in my bathroom that stopped operating.  Not sure what happened.  After they stopped I upgraded Java and the system and still not getting anything.  Any ideas?
v
image.png.ef5ebfe6527be2ab054feda662900377.pngimage.png.6984aa161cfbc29d882eec82094896c0.png
not enough info in the post to troubleshoot, but here's a few starting points:
1) You have the towel bar 2 hour off program currently running while towel bar AM is also true- check out why (if it's a simple logic of if towel bar on, wait 2 hours then off, that would explain it.)
2) Check the date/time/timezone at the top of the AC to ensure it is still set correctly
3) Are the devices themselves responding? Turn it on/off at the device and see if it works manually and that it's status is reporting correctly in the AC
Reply back with that stuff first (Is it plugged in, etc)
First: To post programs please right click on the program and select the last menu item of "Copy to Clipboard". Then paste as text into your forum post. This allows the program to be copied and edited by those helping you if edits are needed. Rather than the helper having to create a program or try to describe edits to an image.
What makes you think they stopped working? Please review the Program -> Summary tab to see the "last run time" for these programs.
The "Towel Bar Morning" program appeared to have last evaluated true (it's partially green - see the wiki for what the colors mean) and I would assume ran at 5am as expected. Were you awake to check if it turned on?
As @SJK points out the "Towel Bar 2 hour off" program seems to be running since it is fully green (means it's running the "Then"). It might be good to also share this program.
The "Master Bath Fast On" appears to have last evaluated "false" and ran the "ELSE" because it is partially red. Maybe the last time that light was turned on it was simply a single on and not a "fast on" that the program is looking for. Also, why are you attempting "fast on" for the devices in the "THEN"? Would "ON" achieve the same desired result? I might test with just "ON" rather than a "FAST ON".  Again, right click on this program an select "RUN THEN". Do the devices respond to the commands?
On the "Towel Bar Morning" program - right click the program and select "Run Then". Does the device turn on?
If you've edited any programs be sure that you SAVE them.
Lastly, please let us know what ISY device you are using (ISY994, Polisy, eisy) and let us know what firmware version (actual number - not just "latest/current version) you are using.
