Hue Bulbs not Responding anymore
I have a handful of Hue bulbs (and some other Zigbee devices) on my eISY.  Within the past week 2 of the hub bulbs stopped working. These are the fancy lightguide glass bulbs. First the one in the master bedroom pendant stopped responding, then a day or so later, the one in my daughter's bedroom pendant.  I factory reset them but they will not re-add to the eISY.  First I tried an update/interview, then the reset with removal from the eISY, but again, will not re-pair.  The lights work with bluetooth on my phone. (They aren't dead). I set up the hue app to verify that they still function.
They are only maybe 2 months old? I doubt the zigbee radio is dead- they failed nearly simultaneously. No power failures or surges etc- I use whole house surge suppression and we have relatively "clean" (stable) power here.
The only interim change is upgrading to 3.9.1 and turning on Matter support. I have no matter devices, and I did try turning it back off without any luck. But this issue didn't temporally appear- I updated to 3.9.1 a week or two after it came out, and this issue started a week ago.
My zigbee network is fine- other devices work, including the other hue bulbs in the house. The regular 60 and 75w A type bulbs are still doing their thing- including those in the same rooms. This isn't a range or interference issue- nothing else has changed and again, everything else just works.
(Side note- have the Polisy running a separate Zigbee network on a separate channel for exterior/window devices- completely separate radio frequency, should not have any issues there- have been happily co-existing since the fall).
Any thoughts? I have no idea what to troubleshoot next.
You mention "hub bulbs" at the beginning but then mention "other zigbee devices".
Are they configured as Hue devices with the Hue plugin, or as straight zigbee devices?
I use some Tuyo clone things for window candles- the ones that you splice into the power cord. Something like those old Sonoff Zigbee basics. Also a couple of Sonoff USB on/off switches for the Lectrofans. All of those items are working just fine as well.
I use no hub or nodeserver for the hue devices- they are linked directly to the eISY using the ZMatter dongle. Same for the other devices mentioned above.
Since you have a Polisy with a separate zigbee network handy, have you tried pairing one of these non responding bulbs on that network? As a test.
Is there a factory reset that you can do on them (usually powering them on and off several times in a short period)?
I did factory reset them multiple times - screw/unscrew method. They were successfully reset.
  • Turn off the bulb for 5 seconds
  • Turn on for 8 seconds
  • Turn off for 2 seconds
I have another one of these bulbs planned for another room when I install the pendant- I just tried to link it to the eISY in place of one of the nonresponding bulbs and it instantly paired, confirming it's not a radio interference issue, etc.
When I use the Xray function to see the devices in the ZB network- I have 16. I only have 10 devices on this network. There's devices there I don't have and the ones that don't respond and have been removed from the eISY. None function- I get errors if I try to interact with or query them.
I have removed them from the zigbee network before removing them from eISY, but they still persist in the all devices table, and if you do a synchronize new and delted with interview they come back. How do I permanently remove them from the network?  Not sure this has any actual bearing on the actual problem, but seems odd I cannot remove anything ever.
Doing some forum searxihng about orphaned zigbee devices I found an acknowledgment in 2023 that this was a bug and would be fixed within the week, followed by a user stating still not fixed a few months later. Other threads were all closed without any replies or that upgrading firmware fixed it.
Perhaps a regression? I'm starting to think that if the controller still thinks the device is there, it's not going to re-pair. But if I cannot delete it, I'm stuck.  I'll put in a ticket to ask.
  • 3 weeks later...
I have an outstanding ticket on Hue bulb issues with ZMatter.  After several exchanges with Michel and Chris, the line went dead on this one, and I had to move on to other priorities, so it is on me for not pressing a follow-up (they put some time in... great response).
I have qty(35) Hue bulbs, nearly all White Ambiance (you can change the Color Temperature), lots of Insteon dimmers and remotes and a smattering of ZWave devices on a Polisy with ZMatter.  These bulbs had been integrated into my Polisy with the Hue Hub Nodeserver before I bought the ZMatter due to Zwave dongle failure.
I have a number of problems with the ZMatter-Hue integration:
A.  Only the E12 Candle bulb will be recognized by the ZMatter as having Color Temperature adjustment.  My BR30, normal E26 bulbs, and special GU10 spot bulbs, all White Ambiance, will not have color temperature option in ZMatter.  Apparently this support is not in UD hands... it is the library they use for Zigbee.
B.  As I was struggling with trying to get Color Temperature to show up on an added Hue bulb, I inadvertently did wrong things when deleting and resetting Hue bulbs to "try again."  Here is what was exposed in my testing:
>>1.  If you "Delete" a Hue bulb without first Excluding/Removing the Bulb from the network, you are screwed.  There is only one recovery for that mistake, and that remedy is massive in my system (an entire reset of the Zigbee System, losing all of your scenes and programs for all 35 bulbs in the system). About 10 straight hours of tedious re-configuration in my system.
>>2.  If you just reset the Hue Bulb (I use a Phillips TouchLink remote to do a hard reset to factory), you are also screwed.  You will likely have to do that reset of the entire Zigbee system losing all your work if you want to use that Hue bulb in your system again.
Here is my thinking on this:
If you delete the device in IoX, that does not delete the device in the polling list in the Zigbee stack micro.  It still thinks it is there.  So if you go to re-add that device you just deleted, it will not even consider adding a device already on its list.  And the only way to get it to re-recognize that device is to reset the Zigbee stack micro (losing all of your Zigbee bulbs/devices).
YOU MUST REMOVE/EXCLUDE THE DEVICE FIRST BEFORE DELETING IT!!!!
Also, if you do an external un-link or factory reset of a Hue bulb, the Zigbee stack micro does NOT auto detect that the device was removed and subsequently remove that device from the Zigbee stack micro device polling list.  So you are screwed again.
As the interfaces for Zigbee are nearly the same as Z-Wave, why don't these same problems expose on the Z-Wave system?
One big difference.  On Z-Wave devices, when you externally factory reset a Z-Wave device, it seems the Z-Wave Stack micro auto-detects that external reset and removes the Z-Wave device from the Z-Wave stack micro polling list.  You can always recover, even if you delete the device in IoX and not remove//exclude it.
C.  The last problem with the ZMatter- Hue integration is that when adding a new device that reveals in several related variables in the device, some of my Hue bulbs do not give an option to "Group" all related variables.  That is messy.
So the Hue NodeServer still lives in my world.
