Lost most data in Teslaevstream
Did you press  authenticate?
Did you ry the test button to make sure you can communicate through the portal?  It seems it is not getting the token
If still an issue enable debug in log and send it do me
can you try TeslaEVpwrSh in the non-production store. It is supporting powershare but it should not affect your car.  There is some strange bug I believe I fixed in this version
I am close to release this version as the real version
Edited by Panda88
Can you run the test button - the results shows below the time on the main page - did you enable access as described in the readme through ISY portal - Also - send me a new log with more data
you have to scroll down to see the result of the test
Did you do the following to enable webhook - It looks to me webhook is not working
(from readme)
Additionally, one must open external access on the eISY/Polisy.
Go to https://my.isy.io/index.htm and log in
Select PG3->Remote Connections on the eISY/Polisy
Make sure that Remote Connection is ACTIVE
To validate if the connection works, there is a TEST button/command on the main page on the node (result shown in the last field in the main page).
Edited by Panda88
added info
It seems your car or FW is too old (not supported) or the key is missing
'response': {'updated_vehicles': 0, 'skipped_vehicles': {'missing_key': ['5YJSA1E44GXXXXXX'], 'unsupported_hardware': ['5YJSA1E44GXXXXX']
The following requirements exists
  • The vehicle must not be a pre-2021 Model S or Model X.
  • Vehicles must be running firmware version 2024.26 or later
Note, this is a Tesla limitation
Hmmm  My car is 2017, but the firmware is v12 (2025.14.1).  If this is not compatible with the plugin, is there a way to reload the prior version of the plugin which worked well?
The previous version is not showing in my purchases, only the EVStream and the beta version.  Any suggestions?  Also, I still have the "Auth for Tesla" app.  Is that still needed or helpful?
I would create a ticket at UDI and mention your can is too old to support the streaming version.  UDI operate the store
You actually did not need to erase the old to try the new
The app is no longer needed - not even for the previous version
