Call a program when a scene is activated
Hello,
I'm trying to setup a situation where I can call a scene (either on or off) through MobiLinc and this would, in turn, call a program in the ISY. Specifically, turning the scene ON would call the "then" path, turning the scene off would call the "if" path. Ideally, if I had a dummy device (or a spare KPL button or something) this would be easy. Add the "Insteon ON" as a condition. But...I don't have either one of these so therefore my scene is empty - I only need it as a means of communication from MobiLinc to the ISY.
You might ask..."Why not just add the program to MobiLinc"? Well, unfortunately my options are more limited here. I can't add it to the favorites the way I want, and "Run IF" or "Run THEN" is much more confusing than my custom names.
Any ideas how to accomplish this?
- Brian
