  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Support for inexpensive smart plugs?
I have a handful of those Eightree/Teckin/whatever their name is this week round smart plugs you can buy on Amazon.
I can control them through Alexa voice control but I'd love to control them with my Insteon mini remote.
I have the EISY and was wondering if thats now possible?
Andrew
Simplest way is to create STATE variables with meaningful names.
Then use ISY Portal to emulate MS devices from each one with 1 value = On , 0 value = Off.
Now use Alexa app to create Alaxa Routines using those pseudoMS elements as triggers to do whatever you want Alexa to do.
After I defined a group of dedicated STATE variable I created an ISY program that is triggered by any STATE variable becoming a non-zero value and WAIT 10 seconds and then set the whole group of STATE variable back to 0 again. This saves many programs, one for each STATE variable by just writing one program for all.
To use:
Set $sAlexa.do.whatever to 1
Reset sSay variables - [ID 006F][Parent 0002][Run At Startup]
        // [Run at Startup] enabled
        $sSay.motionOutsideDoor is not 0
     Or $sSay.occupancyTimerExpiring is not 0
     Or $sSay.securityViolated is not 0
     Or $sSay.welcomeHome is not 0
     Or $sSay.systemArming is not 0
     Or $sSay.systemDisarmed is not 0
     Or $sSay.goodBye is not 0
     Or $sSay.turnOnLights is not 0
     Or $sSay.systemArmed is not 0
     Or $sz_40 is not 0
     Or $sSay.blindLowBatt is not 0
     Or $sSay.blindJammed is not 0
     Or $sz_43 is not 0
     Or $sz_44 is not 0
     Or $sz_45 is not 0
     Or $sz_46 is not 0
     Or $sz_47 is not 0
     Or $sz_48 is not 0
        Wait  10 seconds
        $sSay.motionOutsideDoor  = 0
        $sSay.occupancyTimerExpiring  = 0
        $sSay.securityViolated  = 0
        $sSay.welcomeHome  = 0
        $sSay.systemArming  = 0
        $sSay.systemDisarmed  = 0
        $sSay.goodBye  = 0
        $sSay.turnOnLights  = 0
        $sSay.systemArmed  = 0
        $sz_40  = 0
        $sSay.blindLowBatt  = 0
        $sSay.blindJammed  = 0
        $sz_43  = 0
        $sz_44  = 0
        $sz_45  = 0
        $sz_46  = 0
        $sz_47  = 0
        $sz_48  = 0
To use:
     Or $sz_40 is not 0
     Or $sz_43 is not 0
     Or $sz_44 is not 0
     Or $sz_45 is not 0
     Or $sz_46 is not 0
     Or $sz_47 is not 0
     Or $sz_48 is not 0
        Wait  10 seconds
        $sSay.goodBye  = 0
        $sz_40  = 0
        $sz_43  = 0
        $sz_44  = 0
        $sz_45  = 0
        $sz_46  = 0
        $sz_47  = 0
        $sz_48  = 0
I've never used STATEs before. This doesn't look simple 🤣
I'm not sure where I'd start
Have you ever used variables in your IoX programs? There are two types of variables: integer and state. The difference is that programs can be triggered by the value of a state variable. Furthermore, in the portal you can define an action to be triggered by the value of a (state) variable. then you can use the Alexa app to define a routine triggered by that value.
I have not. I know where those tabs are but that's about it
Then start slow, and learn. Variables allow lots of flexibility in programs. For example, define a state variable, with a name like s_test. Then create a program such as:
If s_test = 1
  Then (turn on light)
Then manually edit the variable value (in the same screen where you defined it) and set it to 1, and watch your light turn on. Variables are a great way to have one program trigger another, etc
