Command after wait never executes
Been a while since I've posted, or even touched my ISY - it's just been working. Today I tried a simple program:
Reset Waterfall - [ID 0014][Parent 0001]
        Time is  2:00:00AM
    And 'Outside / Pool Waterfall' Status is On
        Set 'Outside / Pool Waterfall 3way' Off
        Wait  10 seconds
        Set 'Outside / Pool Waterfall 3way' On
What I am trying to do is every day at 2:00AM I want to check to see if a KPL button is lit. If it is I want to turn off a scene (which will turn off the KPL button) for ten seconds, then turn it back on (which should turn the button back on). What happens is that the scene gets turned off but never turns back on.
This happens if I execute a "Run Then". It also happens at 2:00AM (apparently, since the scene is off when I check it in the morning).
If I remove the wait command and "Run Then" I see the KPL button turn off then back on again.
Solved by paulbates
If the conditions of the program changes to false, the program will stop executing in its tracks during the Wait.
Since you turn off pool/waterfall, that kills the program in the first then statement
What you need to do is have 2 programs:
Reset Waterfall -
     Time is 2:00:00AM
    Run Program Reset Waterfall 2 Then
Reset Waterfall 2
   (No condition)
    Wait 10 seconds
Thanks, I figured it would be something like that. I keep forgetting that ISY programs are really state machines and not sequential programs.
