Migrated to eisy - from/to programs not working
I'm seeing the same issue and I'm running 12-hour format.  I switched from ISY (where it ran perfectly) to EISY two days ago, and now some of my From/To using Sunset/Sunrise (next day) programs appear to not be running correctly.  The port went great, I have a new PLM (replaced a bad one a couple weeks ago) and all my scenes, etc look to be correct.  I'm betting (hoping) there's a bug somewhere with this on the EISY.  I need to go back and pay more attention while running some tests, but I swear that during the "Then" time of day, if I run the program Run If - the Then doesn't trip.  It Does appear that the Else portion Is running when the time period expires - its just the Then portion that doesn't seem to trip correctly.  I have several programs running for different locations - front porch light, coach lights, low-voltage landscaping lights, and they All don't turn ON (then portion) but when I turn them on by hand, they do turn OFF correctly (else portion.)   I HOPE what I said here makes sense!  :-)
Edited by JWBDolphins
Hit <Enter> too soon!
Solved by JWBDolphins
@JWBDolphins
It's possible that during the migration some of the program data got corrupted. Open a program that isn't working correctly and change some of the data, save the program, then go back into the program and change the data back to what you want. Be sure to save the program, then make an eisy backup.
Edited by Techman
If you go to the programs tab, and then to the Summary sub-tab, take a look at Next Run Dates/Times for these programs and see if they make sense. When I first switched from my ISY to eisy, I had similar problems. I believe it was resolved by letting the eisy run for a couple of days and then it cleared up for good.
Take a look here
Thanks @Geddy @Techman and @paulbates.  The next run time/dates look correct, and its been running fine since my initial post!  If I see any more issues, I'll dig into it deeper and create a ticket if I need to.  I very much enjoy the EISY - need to see what I can make it do next!  :-)
  • 5 weeks later...
It's been a month - But - reporting back to say I Figured Out what was going on.  Timed events were not firing, then suddenly they started working.  But things were all messed up between noon and 8 PM.  By messed up, I mean actions were delayed by minutes or wouldn't appear to run at all.  Just a lot of strange events.
LONG story short, my son had added some new Aquarium Lights and had them running on their own timer - between noon and 8 PM.  The Initial problems I had seen, which were After 8 PM, was because he had the lights on manually at that time.  Figuring this out and then Adding a FilterLinc to his lights - has fixed everything.  I'll mark this as Fixed.
Accidently posted too soon....
