June 26, 2025Jun 26 Just finished upgrade from Polisy to Eisy. In the process, I had to re-install my plugins and I also upgraded the ESP Home firmware for my Ratgdo garage door openers. On the UDM side, I had to re-install my favorites and noticed that the garage door nodes not display the "open" of "closed" status, only integers ("0" for closed, "1" or "2 " for open), but the nodes open and close the garage doors normally. Not a big deal but not sure how to fix.
June 26, 2025Jun 26 Probably just need to reboot, this is a requirement (which should be removed within the next couple of firmware updates) to get formatted values after node server install.
