July 2, 20251 yr Upgraded from polisy to eisy. Small issue with configuration custom icon colors in favorites. Tried synchronization but no effect.
July 2, 20251 yr Does the Node have a Status-Value on the Home Tab? I can replicate a similar error for Nodes which do not have Status Properties. If there is no value (defined values) then Advanced Configurations will not work.
July 4, 20251 yr Author No, it does not have a value. it is a rated garage door opener. Interestingly, my other eisy (at another house) displays a value for a similar ratgdo node and I can customize it. Should I delete the node from eisy then add back?
