Gremlins in the mix...
I've had two odd problems occur, not related I don't think.  Last night I created a new state variable for use in a new program.  Everything proceeded as normal, program worked fine.
This morning I find that when I created the new state variable it actually overwrote an existing variable(21).  The new program still works correctly but programs that used variable 21 are of course now messed up.
I have an i3 4 button that works but the leds are always off.  I was going to do a restore but when I attempted this I got this error:
Unrelated of course but now I'm wondering if there is some kind of file corruption happening in my eisy.  Any thoughts on this?  Is there a way to check file integrity, like 'chkdisk'.
Thank you.
The thought I have is minor tear down and rebuild:
  1. I'm guessing that 60:7A:97 is the Insteon id of the 4 button keypad?
    • Delete it and re-add it
  2. For the variable, I would create an additional new variable and update the programs to use it, save and retry.
Thanks for the response,
I should have mentioned that I already fixed it doing exactly what you suggested before I posted.  My concern in reaching out to the group, is whether this might be an indication that there is some corruption going on in the file system.  I've been using UD products a long time and I've never had a variable overwrite another one when being created.  That's also my first restore failure due to a bad file.  Is there a way to check file system integrity on eisy?
I agree with you it's odd. They'll likely want logs from the time you perform recreates to the extent that's possible.
If possible, do that, download the log files and submit a ticket with them and a link back here
