beta testing observations
Thought I'd start a topic under eisy-ui for beta minor observations, @bmercier please take in the spirit of constructive feedback, as well know that each of these items will have a different priority to you versus me.  Maybe others who are helping test can add their observations here.
- noticing if I leave the eisy-ui web page up overnight it stops updating ; even if I do a refresh of the page it does not update with no real indication of "heartbeat"; takes a logout/login.  Was wondering what the timeout period was?  Is there a way to do a heartbeat?
- have been noticing differences between the status on the column view versus the detail view.  A refresh does not always fix it.  Again have needed to logout/login.
- the folder retention of expand/contract has been mentioned but also you cannot search for a folder name and then select it to have it open its contents
- really, really, would like to be able to use my cursor controls to move up and down the list ; contract/expand folders.  As a keyboard user the use of the mouse to move one up or down is maddening (personal rant)
- during search as I start typing I am still getting an 'unexpected application crash' regularly.  refresh of page often resets but sometimes requires a logout/login cycle.
  • Like 2
Thank you very much for the feedback.
There's no specific timeout set. Will need to investigate further as I have never myself let it up overnight. I suspect the websocket connection dies somehow. Will look into it.
Is there a way to get a screenshot? Never seen that happen to me. It might be good to look at the browser console to see what's happening.
@bmercier @sjenkins
I opened the Web UI at my office last week and haven't touched it over the weekend.  I just clicked on that tab and can still see the status of items and control them without doing any refresh or logout/in.  This connection is running over a router to router vpn which further complicates things, and yet, it is still up.  I initiated the connection last week by going to the LAN IP address of my ISY which gets routed through the VPN.
  • Like 3
@bmercier ,
Just wanted to let you know that there is still a difference in behaviour between the local AC and the remote AC / Eisy-UI.
Using my hunterDouglas plugin as an example as I know the plumbing:
reportDrivers() does not update the detail fields in the remote AC / Eisy-UI
works fine in the local AC
ISY programs get the data just fine, so this is a display issue.
Examples below:
local AC:
remote AC:
remote Eisy-UI:
Note:
The field that did update are ones which have changed since the Eisy-UI was running.  The remote AC are blank as I had to restart it to switch from local to remote.
When I press query it runs the reportDrivers() function.  This updates the local(if needed), but not the other two remote versions.  Again the programs run fine.
2 hours ago, sjenkins said:
@bmercier ,
Examples below:
local AC:
remote AC:
remote Eisy-UI:
Note:
This is not a display issue.
This just means that IoX is not sending these events through MQTT because they have not changed.
Will look into it with Chris.
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
      38k
      379.6k
