KeypadLinc 2486D Setup Issues
I have been trying to add a KPL 2486D (8 button) and cannot seem to get the isy99 to recognize it. Hopefully it's something simple that I am not doing correctly. After installing the KPL, I put the isy99 in linking mode, pressed one of the KPL buttons for 10 sec. until it beeped and its light went on. The isy recognized all 8 buttons but says that they are all "unsupported device 1.28". I can control the upper left button with the isy but if I try to turn the other buttons on/off I get an error window saying 'request failed'. I tried going into linking mode again and pressing a different KPL button but it did not make a difference. I have another KPL 2486D in my system and it works fine.
I am currently running isy99 v2.7.15
Any suggestions would be greatly appreciated.
Remove the KeypadLinc and add it back specifying the device address and device type as an 8 button KeypadLinc using New Insteon Device. Likely the KPL has a firmware revision not known to ISY.
You cannot turn KPL secondary buttons On/Off like the load control buttons. To turn a KPL secondary button On/Off define a Scene with the secondary KPL button as a Responder and turn the Scene On/Off.
Thanks LeeG! That did the trick. I really appreciate the response. Now I just have to find a way to reattach the hair I pulled out trying to figure the problem out!
Hi Michel,
I am running v2.7.15 and I'm not sure what url I'm using but will check on it. For now, off to vacation!!
Thanks for your response
