Newest IoX release
I have been watching, with interest, the discussion on the newest software and UI. I understand that one must use the portal account credentials to login. Is this suggesting that a portal account is now required to use an EISY? Does this suggest that the newest version of iox requires an Internet connection to work ?  Am I correct in my understanding that the old Java interface is still available and, if so, is that the only way to access the EISY locally?
@oberkc, I found this in the eisy-ui wiki:
Using eisy without connectivity
Although eisy-ui requires your portal username and password, it will work without Internet connectivity.
When you log in;
  • If there is connectivity, it will check your credentials against portal.
  • If there is no connectivity, it will authenticate you using a cached copy of your credentials.
    • The cached copy of your your portal password is encrypted using one-way encryption (It's technically a hash of your password).
In addition, if there is no connectivity, a few features will be disabled, such as:
  • The PG3x/Plugins store.
  • The PG3x/Plugins purchases page.
Plugins themselves will continue to run, unless they need connectivity.
I'm adding this based on my own experiences: eisy will continue to run the same as the plug-ins unless a node needs external connectivity.
The Java based Admin Console still works, but please note the release notes for eisy-ui; you may need to use your portal credentials to login to the old Admin Console.  It's based on some factors I don't totally understand, but since I installed eisy-ui, I have to use my portal credentials to login to the Admin Console.  It still works the same.
Thanks for the pointers.  That gives me some relief.  I am still stuck with the perception that a portal account is required, however.  If one does not have a portal account, does the system not work?  If one has a portal account but later chooses to cancel it, does the system quit working?
Edited by oberkc
There is a difference between “having a portal account” and “having an active subscription”. I think since the eisy came out it needed a portal account so setup and buy plugins. If does not require a subscription to be active. I expect the eisy-ui to be the same. It is trying to login with portal credentials, but that does not require a subscription. It also does not require internet connection (as pointed out above, from the wiki).
Thank you all for the references.  I have forgotten, or did not realize, that there was a difference between having a portal account and having an active subscription.
Ultimately, I feel extremely comitted to the “ISY” system and it is quite imbedded into my house.  Though I have every reason and hope in the continued viability of universal devices, I very much want to avoid having to suddenly remove this system should any external resource such as portal accounts (active or otherwise) become disabled or eliminated for any reason, rendering my sytem inoperative.
