k.root Posted 5 hours ago Posted 5 hours ago I am adding my very first Zwave device. So I may not be doing something correct. Thank you in advance for your assistance. I have an EISY running 5.9.1 and the USB zmatter. The Insteon devices work fine. I’ve tried several ways and no matter what I am never prompted for the device pin. It also took several tries to figure out how to get the device in pairing mode. At one point it was there as zy002… then it disappeared. Got it back in now as zy003… however it says S2 AUTH UnAuth. When it was in as zy002… it said the same thing. It adds multiple devices all starting with zy003… they all say the S2 AUTH message and contain no data. at one point I turned off S2 in IoX to no avail that may have been when it disappeared. Can’t remember as I’ve tried so many things and watched so many videos. Unfortunately none of them were for the EISY so just gave me insight to how the process works on some controllers. I’ve tried from my iPhone in the UD mobile app the smart add scan the QR code. I’ve tried from my iPhone on the UD mobile app the regular add. I’ve tried add from the IoX. If I can reset the Zwave network and start all over I am okay with that and guidance to the correct way to do it. if I can edit a config file to enter the DSK pin I’m okay with that too. Again with guidance how to do it. Providing that’s even an option with S2 security. Thank you in advance for your assistance. Quote
