Added a second Hub (X3 Smart Home Gateway)
pkauf
Go to solution Solved by Panda88,
I started out with just a speaker hub, but got an additional hub that has battery backup so I can get alerts if power drops - when I added it to the app, etc. its there and working fine.  How do I get the plugin to recognize it?
if you can send a log with power and without power i can tage a look.   they do have a dedicated device for this.
i do have the pro hub (probably similar to X3 hub) and it may have the same reporting - I'll take a look when I get some time
Cool, I'll kill the power and grab the log.  Kinda new to Yolink - where can I get that log-in the app somewhere?
The pg3x log specifically under the yolink plugin. Set it do debug level
@paulbates - are you sure this is what he wants?  @Panda88  indicated he ignores the hubs that are not the speaker hub, so why would there be an messages generated from the plugin?   I assumed he was looking for messages coming out from the hub itself.  Just want to make sure I grab what is needed.  Thanks!
You need to restart the node after enabling the debug level
Devices still send data - I just do not process it (as I do not know what to do with it :-)
Should be able to see what is reported and then make the needed changes
Cool, thanks for confirming, just didn't want to send the wrong info.  @paulbates - thanks, sorry, should have trusted you! 😀
I don't see any messages in the logs from the X3 Hub, only the speaker hub, but I may be misreading it.  Let me know if this helps.  It does show up in the device log, but maybe it isn't putting it out via the api . . .
YoLink_8-19-2025_32932_PM.zip
I have this device and it works
Looks like I do not log the "unknown" X3 hub.   I'll see what I can see from my own system to see if I can deermine if codes are sent (or not sent)
Cool, if you can't, let me know and I'll just get the power device.  it's only like 20.00 . . .
      379.8k
