pkauf Posted August 18 Posted August 18 I started out with just a speaker hub, but got an additional hub that has battery backup so I can get alerts if power drops - when I added it to the app, etc. its there and working fine. How do I get the plugin to recognize it? Thanks Quote
Solution Panda88 Posted August 19 Solution Posted August 19 The plugin ignores the HUBs (besides speaker hub) as they cannot do anything besides being a connection to the cloud 1 Quote
pkauf Posted August 19 Author Posted August 19 Well, this hub has alerts for power loss which I was hoping to monitor via the plug in … Quote
Panda88 Posted August 19 Posted August 19 if you can send a log with power and without power i can tage a look. they do have a dedicated device for this. i do have the pro hub (probably similar to X3 hub) and it may have the same reporting - I'll take a look when I get some time Quote
pkauf Posted August 19 Author Posted August 19 Cool, I'll kill the power and grab the log. Kinda new to Yolink - where can I get that log-in the app somewhere? Quote
paulbates Posted August 19 Posted August 19 37 minutes ago, pkauf said: Cool, I'll kill the power and grab the log. Kinda new to Yolink - where can I get that log-in the app somewhere? The pg3x log specifically under the yolink plugin. Set it do debug level Quote
pkauf Posted August 19 Author Posted August 19 @paulbates - are you sure this is what he wants? @Panda88 indicated he ignores the hubs that are not the speaker hub, so why would there be an messages generated from the plugin? I assumed he was looking for messages coming out from the hub itself. Just want to make sure I grab what is needed. Thanks! Quote
Panda88 Posted August 19 Posted August 19 You need to restart the node after enabling the debug level Devices still send data - I just do not process it (as I do not know what to do with it Should be able to see what is reported and then make the needed changes 1 Quote
pkauf Posted August 19 Author Posted August 19 30 minutes ago, Panda88 said: You need to restart the node after enabling the debug level Devices still send data - I just do not process it (as I do not know what to do with it Should be able to see what is reported and then make the needed changes Cool, thanks for confirming, just didn't want to send the wrong info. @paulbates - thanks, sorry, should have trusted you! 😀 Quote
pkauf Posted August 19 Author Posted August 19 I don't see any messages in the logs from the X3 Hub, only the speaker hub, but I may be misreading it. Let me know if this helps. It does show up in the device log, but maybe it isn't putting it out via the api . . . YoLink_8-19-2025_32932_PM.zip Quote
pkauf Posted August 19 Author Posted August 19 And, if for some reason this isn't working, I could always get the following - do you support it? https://www.amazon.com/YoLink-Long-Range-Wireless-Monitoring-Required/dp/B09NR1YXHH/ref=sr_1_1?crid=21V2VVEZE3Z9U&dib=eyJ2IjoiMSJ9.s-GdXmoujhVVpoLTqRIotFp8xtys6Kqx2J7VRf9aOySyZ6KGPIljLywfZnclIjogcwmuFFyBfFlEYAopg1U5SQvNj9hDXr2En-ZAODv3331EebOiIrD5710yU0ljPgobVKSL8ztpCdkkiWozcpaT8LDSZKron8CNTiVNJRHTX-DaQMum4LBpgDAvUi9UaPeP_L8XYg9o94KrQVr2nE8qkAPrTsEPzCiiCWmvfvG2vmU.3VW2sRzGzzWWhk41UcgCDI3xn7BENfUw5fwQmE7ncjQ&dib_tag=se&keywords=yolink%2Bpower%2Bfailure%2Bsensor&qid=1755635901&sprefix=yolink%2Bpower%2B%2Caps%2C113&sr=8-1&th=1 Quote
Panda88 Posted August 19 Posted August 19 I have this device and it works Looks like I do not log the "unknown" X3 hub. I'll see what I can see from my own system to see if I can deermine if codes are sent (or not sent) Quote
pkauf Posted August 19 Author Posted August 19 1 hour ago, Panda88 said: I have this device and it works Looks like I do not log the "unknown" X3 hub. I'll see what I can see from my own system to see if I can deermine if codes are sent (or not sent) Cool, if you can't, let me know and I'll just get the power device. it's only like 20.00 . . . Quote
Panda88 Posted September 6 Posted September 6 (edited) I am looking at this now - do you know what states exist - It seems there is supplying and charging Do you know of others? I believe there are minimum 4 as I get 2 and 3 from API - so 0 and 1 must also exist - likely battery empty and unknown, but I am just guessing I guess there are 2 parameters - DC and battery state Edited September 6 by Panda88 Quote
Panda88 Posted September 6 Posted September 6 It looks like my LocalHub does not generate an event when power is not supplied - Yours may be different - you can poll and get th info, but it does not generate an alarm like the powerSensor does Quote
