Posted August 25Aug 25 Hi - brought the old unit out of retirement - and after the factory reset was able to get into the box. However, I will not be using Insteon, only Z-Wave but the unit is booting to safe mode. In my policy, I see the option to disable Insteon under system but not under 5.3.4 which is the last firmware? Anyone else have success? Thank you-Steve
August 25Aug 25 1 hour ago, SteveT said: the unit is booting to safe mode First off….what Z-wave card do you have in the device? If it is not the 500 series you might need a lower version that supported the 300 series card. If you have the 500 then you want to get the firmware version that doesn’t have a PLM. From the 5.3.4 release post you’ll see this: Quote 3. Download firmware - ISY 994i Series including Z-Wave support - ISY 994i ZW, Z, or ZS Series (Z-Wave/Zigbee and/or if you do NOT have a PLM) You want to download the second option “do NOT have a PLM”. This will allow the ISY994 to work without Insteon support and thus not looking for a PLM and will not be in “safe mode”.
August 25Aug 25 Author 8 hours ago, Geddy said: First off….what Z-wave card do you have in the device? If it is not the 500 series you might need a lower version that supported the 300 series card. If you have the 500 then you want to get the firmware version that doesn’t have a PLM. From the 5.3.4 release post you’ll see this: You want to download the second option “do NOT have a PLM”. This will allow the ISY994 to work without Insteon support and thus not looking for a PLM and will not be in “safe mode”. great- thank you I will try that.
August 26Aug 26 Author Onto the next issue - after doing the factory reset - and trying to do the upgrade, or save programs I get a "tcp client DNS error" [my.isy.io] -- With the upgrade, I get a "Upgrade failed: failed uploading file (reported written size is invalid)... Java.io broken pipe. Previously it had been on the portal, and since expired, but i deleted and rebooted in case that was the issue. Related error: ? "Could not open config file to read /CONF/HZWNDKEY.TXT", Could not open file "/CONF/PORTALS.PSF" stuck! thanks, Steve Edited August 26Aug 26 by SteveT
