my car is detected but all numbers are zero
I just tried out the new TeslaEVStream nodeserver and I get all of the nodes but they are all devoid of data.  any suggestions?
Solved by Panda88
Can you enable debug restart node and send me link
My guess is you did not go through the authenticate process (press the authenticate button)
Also - did you preform the test to ensure webhook is working
well, I tried re-authenticating it.  then I checked the webhook and now, it is working!  I'm not sure what changed but, Thank you!!
I updated to the newest version (0.2.10) and it is still not working, again.   I tried re-authenticating it and that hasn't helped either.  any suggestions?
  • 4 weeks later...
I kind of gave up.  I'm selling my tesla in a couple of months.  if you would like my help, then I'm happy to get back into trying to fix this (mostly because it may help you and other people).  but if I'm the only one with this problem then I'll give up.
FYI:  I did try installing the nodeserver in a different slot and went through the process and it still didn't work.
Sorry to hear that is still not working - there is something in your setup (most likely the tesla APP) that is causing this. As you are selling your car, I will not spend more time on this unless others are having similar issues
