Upgrade to 5.9.1 from 5.8.4 on Polisy
I am at 5.8.4 and figured I should upgrade to 5.9.1 on my Polisy as 6.0.0 was just released and does not support Polisy.  Anyone know where I can get the image and instructions?  I figure if I hit Upgrade Packages I will go to 6.0.0 and brick my Polisy.
Edited by CPrince
Solved by Techman
If you click on upgrade packages it will update your polisy to the latest available package for the polisy
Thanks I did that and it worked.  5.9.1 is the IoX. So what is the OS ver and where is it found?  I know I am not at 10.3.  I Thought the 10.3 OS in this latest 6.0.0 release referred to Mac OS.
FYI - has NOT been released yet. The announcement basically said to stay tuned.
Quote
– Using eisy?
You’ll be notified of the upgrade availability for OS 14.3 and IoX 6.0.0 no later than 09/29/2025. Be sure to subscribe to our Product News and Announcements so you don’t miss it.
On 9/22/2025 at 11:40 AM, Techman said:
To view your Polisy firmware version:
https://poisy.local:8443/WEB/sysconfig.txt
I think that link is for eisy. At least that's what I see when I hover my mouse over it.
Because I own a polisy, it doesn't work for me unless I copy your link and change eisy to polisy.
@Athlon I had to do that too.  I just used the IP address:8443 instead of polisy.local:8443 .  Lots of info in that file!
yep
