Program running unexpectedly.
I kind of get why this is happening but I don't.  Just can't wrap my head around it.  I thought of breaking it up into 2 programs but don't think that will work.
I am looking to clean up this program.  It works fine with the exception that it runs the “Else” part at 3:01 AM when I update my flag in another program.  The flag is a heartbeat flag.  If the flag stays the same, it still runs at 3:01 AM.  These are unnecessary messages.  I only wat the 8:55 and 5:55 message. My gate sensor does not have a heartbeat.  It does have a Unix time stamp.  So, I look to see if yesterday’s stamp is less than today’s stamp and if so, set my flag to 1.  If not, I set it to 2.
Gate Sensor Problem - [ID 0076][Parent 006C]
             Time is  8:55:00AM
          Or Time is  5:55:00PM
    And (
             $sSouthGate is not 1
          Or $sNorthGate is not 1
        Send Notification to 'Chris email' content 'Gate Sensor Problem'
        Wait  5 seconds
        Send Notification to 'Pushover' content 'Gate Sensor Problem'
        Wait  5 seconds
        Set 'Notification Controller / UD Mobile' Send Message Content 20 Notification ID (ID=20)
        Send Notification to 'Chris email' content 'Gate Sensor Normal'
        Wait  5 seconds
        Send Notification to 'Pushover' content 'Gate Sensor Normal'
        Wait  5 seconds
        Set 'Notification Controller / UD Mobile' Send Message Content 21 Notification ID (ID=21)
Solved by larryllix
Whatever your SouthGate or NorthGate does will trigger evaluation of your program.
If anything triggers evaluation the two times with never be true and Else will always get run.
Time triggers are always false unless THEY, THEMSELVES trigger the evaluation, even if the time is exactly the same time.
Single time triggers cannot be used for logic filters.
FIX? Change your NorthGate and SouthGate variabes to INTEGER types so they don't trigger your program, and only your times trigger it.
@larryllix Thanks. "If anything triggers evaluation the two times with never be true and Else will always get run."   This is exactly where I got stuck and did not know how to fix.
My problem is my lack of good knowledge of integer and state variables.  I changed the $SouthGate and $NorthGate variables to integer.
Else statements that actually perform actions should be very rare. Usually they'll just do something like reset a variable.
@Guy Lavoie I would agree.  This code was left over from some old sensors with actual heartbeats.  Rather than remove some in-depth code and rewrite some new code; I patched the old.  I was being lazy.  But at the same token it was why reinvent the wheel.  I was like it is all here, just use the "Else"!
