Linking new insteon devices not working
12 minutes ago, tlightne said:
Since the 994 is no longer supported by UD I believe you can no longer upgrade to the PRO.
lol... go figure. What are my options exactly? is there a upgrade path that doesn't require that I "resync" all of my devices and rebuild my scenes and programming?
Upgrade to an eISY. I believe there is a discount code for 13% off right now. It will give you plenty of headroom and ability to leverage great current and around the corner (next few days) features.
Since you do not have wave, it’s typically very straightforward.
If you do the upgrade, take note of your PLM which I’m sure is serial and get the serial to usb converter cable. I too updated my serial PLM before installing with up voltage specification capacitors and it’s been going for years now.
Also, since you don’t have zwave, it easy typically very easy conversion but do your ho,work on the upgrade process first.
If you do the upgrade, take note of your PLM which I’m sure i saw was serial and get the serial to usb converter cable. I too repaired my PLM with new capacitors and it’s been going for many years now.
thanks
6 hours ago, hart2hart said:
Upgrade to an eISY.
Upgrading to an eISY is a nice way of supporting UD.  I did that earlier this year when UD sent out a notice that eISY prices would be going up because of tariffs.  For that reason, I have a decommissioned ISY 994i PRO.  It was purchased in Jan 2013, and used through July of this year.  It's yours for the price of shipping (~$8 in USA), if you want it.  It's on v5.3.4, so I think you'd need to upgrade your existing ISY first before you could create a backup that could be restored to it.
Edited by kclenden
Yes as the ISY994i is discontinued. All things like add PRO are no longer available.
