Posted September 28Sep 28 It used to be 100% stable but now I'm still facing issues with Alexa commands to turn on/off from time to time. It answers "ok" but the lights/outlets do not respond. How can I troubleshoot it?
October 8Oct 8 Same issue here. Things will work fine for a while and then they don't. As an intermittent issue that isn't always repeatable, I don't know that there is an easy way to troubleshoot. There are some ideas on other threads regarding room / group names that might be helpful. As a side note, I think these errors are more recent within the past couple of months. I don't think the new version of Alexa made things any better.
October 9Oct 9 @MFBra or @zorax2 Please give more details so others might be able to help. But there have been reports of the new Alexa+ is having issues with home automations or skills in general (Other posts on the forums have mentioned issues). Please post more about your situation: UD Device in use? Firmware number (specific number not just "current"/"latest")? What kind of devices are not responding (Insteon or other tech)? Are you controlling an actual device, program, or scene? Always best to include more information rather than just saying, "something isn't working 100% of the time". It's kind of hard to troubleshoot...that's probably why there were no replies to initial post a couple of weeks ago. On 9/28/2025 at 12:19 PM, MFBra said: How can I troubleshoot it? Simple troubleshooting: Power cycle Alexa device(s) Powercycle UD Device Control device with other method (UD Mobile, Admin Console, Physical switch) Confirm UD Portal license is current Confirm UD Portal is using proper device (UUID) and linked to Alexa Look at "My Profile" and see that preferred UUID is correct Click on Connectivity and confirm UUID is active UD device Confirm Alexa Skill is linked to UD Portal account - might need to unlink/disable skill and then re-enable to re-link
October 11Oct 11 Author On 10/9/2025 at 12:15 PM, Geddy said: @MFBra or @zorax2 Please give more details so others might be able to help. But there have been reports of the new Alexa+ is having issues with home automations or skills in general (Other posts on the forums have mentioned issues). Please post more about your situation: UD Device in use? Firmware number (specific number not just "current"/"latest")? What kind of devices are not responding (Insteon or other tech)? Are you controlling an actual device, program, or scene? Always best to include more information rather than just saying, "something isn't working 100% of the time". It's kind of hard to troubleshoot...that's probably why there were no replies to initial post a couple of weeks ago. Simple troubleshooting: Power cycle Alexa device(s) Powercycle UD Device Control device with other method (UD Mobile, Admin Console, Physical switch) Confirm UD Portal license is current Confirm UD Portal is using proper device (UUID) and linked to Alexa Look at "My Profile" and see that preferred UUID is correct Click on Connectivity and confirm UUID is active UD device Confirm Alexa Skill is linked to UD Portal account - might need to unlink/disable skill and then re-enable to re-link Thanks for the help : Eisy Version : IOX v.5.9.1 (2025-03-05-10:18:08) IoX v.5.9.1 (2025-03-14-16:21:41) eisy (5226) OpenADR (21010) Networking Module (21040) Portal Integragion - UDI (21075) Z-Wave Module (21100) A10/X10 Module (21060) Portal Integration shows Registered Internet Access disabled Power cycle Alexa device(s) - Did Several times Powercycle UD Device - Did at least twice Control device with other method (UD Mobile, Admin Console, Physical switch) - Yes, even with Alexa it sometimes works, its "erratic" Confirm UD Portal license is current - Portal Integration shows Registered Confirm UD Portal is using proper device (UUID) and linked to Alexa - Yes, just have one eisy registered Look at "My Profile" and see that preferred UUID is correct - Correct Click on Connectivity and confirm UUID is active UD device - Correct Confirm Alexa Skill is linked to UD Portal account - might need to unlink/disable skill and then re-enable to re-link : its is connected. The issues I'm facing : - Alexa says "ok" to a command but it never happens - Alexa says "ok" to a command but it takes 5-10 seconds to execute - Alexa says "ok" to a command and it works "almost immediately" Devices failing are majority Insteon : - (2443-222) Micro Module On/Off v.48 - (2876SB) Icon Relay Switch v.39 - (2477D) Dual Band SwitchLinc Dimmer v.45 - (2856S3B) Icon Relay 3-Pin v.39 - Sonoff Devices, firmware tasmota, thru MQTT If a command fails, repeating it usually works flawlessly, but sometimes it doesn’t, there is no distinction of which Alexa devices I'm talking to, I have 4 (3 distinct models : 1 3rd Gen, 1 Dot and 2 Spots) Thanks in advance!
October 12Oct 12 Alexa+ puts UDI at the bottom of its internal list making it unlikely to match. It will trigger any other sound alike (or close) device before the UDI Alexa keywords. Just say "Alexa, UDI device take priority over all other devices" and everything will magically work.
October 12Oct 12 Author 17 hours ago, Lore said: Alexa+ puts UDI at the bottom of its internal list making it unlikely to match. It will trigger any other sound alike (or close) device before the UDI Alexa keywords. Just say "Alexa, UDI device take priority over all other devices" and everything will magically work. The skill is not "UDI", great it worked with you...
October 13Oct 13 8 hours ago, MFBra said: Alexa+ seems to have figured out what I wanted, but with AI you never know. I was pretty methodical. When I say undo prioritizing Universal Devices my issues return. I suppose using the actual skill name would work too. In my case, I had a hue bulb named "study bulb" that was triggering instead of my isy.io "study" scene, showing Alexa+ takes partial matches and is going through Hue names first. I also had my roomba starting when I tried to trigger my isy.io "movie" scene from a distance. Both issues vanish when I ask Alexa to prioritize U.D.I. devices, or Universal Devices devices, or any variation of that.
October 13Oct 13 On 10/11/2025 at 7:30 PM, Lore said: Alexa+ puts UDI at the bottom of its internal list making it unlikely to match. It will trigger any other sound alike (or close) device before the UDI Alexa keywords. Just say "Alexa, UDI device take priority over all other devices" and everything will magically work. I tried a few variations of this: "Alexa, UDI device take priority over all other devices" and Alexa to prioritize U.D.I. devices, or Universal Devices devices, or any variation of that. Alexa replies that she can't prioritize specific device manufacturers. All smart home devices will work regardless of their brand.
October 13Oct 13 Not sure why I got the results I did, but more testing shows the AI inconsistent and will change what it does based on prior commands. In my ISY "study" vs Hue "study bulb" case, if I said "turn on study" it would use the ISY scene. If I said "set study to purple", it would use the Hue "study bulb". If I then said "Turn off study" after asking for a color, it would also use the Hue "study bulb", where normally it would use the ISY "study" scene. I was wrong and there doesn't appear to be a way to set skill priority, however, routines take priority over skills, so I was able to create Alexa routines to mimic the ISY skill behavior. Routine voice "turn study off" sets study to off and always works. Edited October 13Oct 13 by Lore
October 13Oct 13 Author 5 hours ago, Lore said: Not sure why I got the results I did, but more testing shows the AI inconsistent and will change what it does based on prior commands. In my ISY "study" vs Hue "study bulb" case, if I said "turn on study" it would use the ISY scene. If I said "set study to purple", it would use the Hue "study bulb". If I then said "Turn off study" after asking for a color, it would also use the Hue "study bulb", where normally it would use the ISY "study" scene. I was wrong and there doesn't appear to be a way to set skill priority, however, routines take priority over skills, so I was able to create Alexa routines to mimic the ISY skill behavior. Routine voice "turn study off" sets study to off and always works. To avoid any potential “naming issue,” I’ve tried using the Alexa App. My first attempt failed, but my second try was successful. The device is in Portuguese, but the first picture shows a message indicating that the device isn’t responding and is waiting… (I’ve removed the address and names from the picture.)
October 13Oct 13 On 10/11/2025 at 5:26 PM, MFBra said: Alexa devices I'm talking to, I have 4 (3 distinct models : 1 3rd Gen, 1 Dot and 2 Spots) Thanks a lot for the additional information...very helpful. As @Lore points out Alexa+ has corrupted some home automation processes. Make sure you're not on Alex+ (or whatever it's called). There is a post somewhere about this and how to revert. I've not tried the new system yet so not sure how it reacts and not sure how to get back to the basic Alexa/Echo setup. If you do revert you might need to re-link the UD skill. It seems things should be working. Are you able to control the devices from another app? UD Mobile? Or even able to reliably control these devices from the Admin Console? It could be a network issue (unlikely, but possible). Or it could be a communication issue with the PLM. Trying to control the other devices 100% activation with other apps or admin console might help determine if you have Insteon communication issue. If you're having to try multiple times with other options you might need to check for noise (see the wiki for troubleshooting suggestions). If it's a bad PLM there are steps for troubleshooting that too in the wiki (I believe). https://wiki.universal-devices.com/ It's strange that Alexa would have issues on first attempt, but then ultimately work. It's likely noise in the lines. Either something has been added that causes noise or something is failing and suddenly adding noise to the power line in the property. Key culprits have been garage doors, failing phone chargers, high amperage appliances. It's not easy to pinpoint so don't just look at new things added.
October 13Oct 13 SOLUTION - The problem is not UDI, EISY, ISY related - all Alexa Plus - see below:By happenstance, my neighbor was over for lunch and I mentioned how I've experienced some inconsistencies with my home automation using Alexa. I've had voice commands work intermittently or delayed. Just weird stuff.My biggest gripe recently was I could not turn on my mudroom lights via Alexa voice command. The mudroom lights work instantly via the Admin Console, the UD Mobile app and via the Alexa app on my phone using turn on/off. I played around with a few things and renamed my voice command (spokens) for the mudroom lights to "Romeo" and the mudroom lights ended up working properly. I switched the spoken back to "Mudroom Lights" and it wouldn't work even though it sometimes did the beep to acknowledge the command.IIRC, my neighbor uses both Hubitat and Homekit. He said he was having the exact same problems I demonstrated and described to him stating he spent hours trying to figure out why one chandelier wouldn't work correctly.The common thread was we both purchased Amazon Echo Shows that had the software updated to the new Alexa Plus.While we might be able to rollback to regular Alexa (I haven't decided whether to look at doing that), we're probably on the Alexa Plus train as I'll bet they won't want to maintain separate software for an extended period of time. Alexa Plus is initially going to be a premium / paid option that does have value but I sure hope there is a way for them to better integrate smarthome devices as we UDI device users aren't the only ones having this issue.
October 14Oct 14 Yup, Alexa+ is sort of a nightmare as far as smart homes with a large number of keywords and devices. Alexa+ automatically created groups for me, with the same names as ISY programs! Thanks. Alexa+ will "try" to understand your meaning from context, throwing old fashioned keywords out the window. Thanks. On top of all this Alexa matches what it hears to what it expects and doesn't hear that well. I always ask "what do you think I said?" and it's surprising. The only saving grace, is that if you have something you always say the same way, and want it to just work, create an Alexa Routine, even if the ISY keyword should work. Alexa voice routines seem to be outside of Alexa+'s artistic interpretations and require you say exactly the text you entered and they take priority over keywords from skills.
October 14Oct 14 I agree with the idea of using Alexa Routines. Been using them for a long time to keep her from getting confused (misinterpreting what I actually want her to do).I have had no issues since upgrading to Alexa Plus a few months ago. My 'routines' are programmed based on what I want to say - not on what I think she wants to hear.
