Nodes don't show in new UI
After clicking on the setting icon (gear), then 'Add Tiles', I get this:
Create Tiles From Nodes
Error: Request failed with status code 404
If I click on the Main Menu, then Nodes, a list of (I think) nodes shows briefly, then this:
  1. Home
  1. Nodes
I've read through the wiki and it seems they should be working - is it because I have a Polisy?
Solved by Athlon
Figured it out. 😀
Went to Main Menu/Settings/Reinstall Plugins and clicked on Reinstall All Plugins.
I can now add tiles.
I have this same issue, however reinstalling all plugins did not resolve the problem
How did you reinstall them? (From what screen?)
Hi,
From the home page I used the menu button in top left corner then settings then plug ins
Hi,
Yep, that's how I did it. Someone else will have to chime in here.
  • 4 weeks later...
Has anyone found solution to this? After upgrading yesterday and now at 0.7.1 of eisy-ui, I also am getting the 404 error message when I try to add a tile. Have done 2 reboots and 3 Re-install All Plug-ins. No joy.
