eisy-ui with no status / Subscriptions not working
Here's a solution if you get any of these symptoms:
  • Starting Admin Console, you get a message "Starting Subscription..." which does not go away
  • In eisy-ui, you get no status
  • In UD Mobile, you get no status
If you get any of these symptons, please start the admin console and "Upgrade packages"
Explanation:
In some cases, your unit may be having a bad certificate that eisy-ui uses to connect internally. If so, you can't get any subscription.
Upgrade package will bring eisy-ui to version 0.6.3 which will detect the bad certicate and have it recreated.
Edited by bmercier
Enhanced eisy-ui: It is no longer necessary to restart UDX
A problem just started with my tablet and laptop pc that has been logged into eisy-ui for many days. I now get "Error Loading Profiles".
When clicking on nodes i get "Error 404"
Programs and states seem to load ok.
It does work ok on my desktop pc.
Any suggestions.
UPDATE: Problem fixed. Had to use https.
Edited by garybixler
I just fixed the "Starting Subscription..." thing as indicated, by upgrading to 0.6.3.
So far everything is working as it should.
