bmercier Posted Friday at 08:34 PM Posted Friday at 08:34 PM (edited) Here's a solution if you get any of these symptoms: Starting Admin Console, you get a message "Starting Subscription..." which does not go away In eisy-ui, you get no status In UD Mobile, you get no status If you get any of these symptons, please start the admin console and "Upgrade packages" Explanation: In some cases, your unit may be having a bad certificate that eisy-ui uses to connect internally. If so, you can't get any subscription. Upgrade package will bring eisy-ui to version 0.6.3 which will detect the bad certicate and have it recreated. Edited Tuesday at 06:26 PM by bmercier Enhanced eisy-ui: It is no longer necessary to restart UDX 1 3 Quote
garybixler Posted Friday at 10:35 PM Posted Friday at 10:35 PM (edited) A problem just started with my tablet and laptop pc that has been logged into eisy-ui for many days. I now get "Error Loading Profiles". When clicking on nodes i get "Error 404" Programs and states seem to load ok. It does work ok on my desktop pc. Any suggestions. UPDATE: Problem fixed. Had to use https. Edited Friday at 11:19 PM by garybixler Quote
Guy Lavoie Posted yesterday at 12:51 AM Posted yesterday at 12:51 AM I just fixed the "Starting Subscription..." thing as indicated, by upgrading to 0.6.3. So far everything is working as it should. Quote
