October 15, 2025Oct 15 Cant get node server running right. Entered uuid and secret key but my devices not showing up ( I only have 2 at the moment, a contact sensor and a thermometer) Yo link hub connected by ethernet.on polyglot it shows one node which in admin console is labeled setup. have tried re booting eisy and hub but no joyDo not see install instructions anywhere but puzzled what else I would have needed to do,Any help really appreciated as I really want to get this running
October 16, 2025Oct 16 Author maybe my bad. Just noticed the nodeserver is for the yolink local hub 1606. I have the 1603 hub which came bundled. If anyone can confirm this is an issue would appreciate it. Further, if anyone knows how I can get a 1606 would appreciate that too! Sold out at yolink site
October 16, 2025Oct 16 Can you PM me a log file with debug enabled and I'll take a lookAre you sure there are no empty spaces in the UUID / secret?Hub should be fine - but you need to configure the cloud portion - local only works on 1606There should be install instructions in the more detail portion
October 16, 2025Oct 16 Author so tried a new uuid/secret id w/o any luck. PM'd the log . FYI, clicking more info goes to a dead link. Thanks Edited October 16, 2025Oct 16 by grossmd
October 16, 2025Oct 16 Solution Looks like you are trying to use the YolinkLocal node - Did you set it to CLOUD in the config - hybrid and local requires the local HUB (log shows it is trying to access the local as well) - keep the local keys blank (Looks like you entered the cloud credentials there)Setting it to cloud (only) should allow this node to progress - but please make sure you have the local fields BLANK until you get the local hubYou can also try the Yolink (no Local) - unless you plan to get the local hub in the future
October 16, 2025Oct 16 Author Sorry , as mentioned can’t access instructions . With the above it’s working g fine! Thanks so much for the rapid response!
October 16, 2025Oct 16 Yes - I realized there was a problem in the release - should be fixed now (I hope) if you reinstall
