October 21, 20251 yr I am running the new beta of UD Mobile. Issue DOES NOT exist with release version of UD Mobile. It’s something to do with the latest EISY-UI because it just started and I see the issue (somewhat) in the UI interface also.TimeData and the sub called SunData show (sometimes randomly on one device it works) the address like GV0, GV1 instead of the names. I rebooted the system multiple times and even reinstalled and rebooted.In the UI interface it shows the name of the nodeserver (both TimeData and the sub called SunData) but no node info at all. Just one entry for the name.Again in the release version of UD Mobile (not using new interface) it does show the fields.I confirmed on multiple devices and rebooted multiple times.Works Fine in Admin Console Edited October 21, 20251 yr by macjeff
October 21, 20251 yr Author multiple times after multiple reboots I also reinstalled plugin but same slot. Have not tried another slot
October 21, 20251 yr Benoit has released an update, 0.7.1 of eisy-ui. Did that make any difference? I have not had time yet to upgrade either of my machines since I'm away from home for a bit. I will look into it if necessary as soon as I can.
October 21, 20251 yr Author The update fixed issues with a lot of plugins but timedata still has issues and sundata is blank in both EISY-UI and UD Mobile beta (works with the release of UD Mobile)
October 24, 20251 yr I too am using the latest beta UDM with eisy-ui 7.1 and everything looks good here. Unfortunately, I do see the same display as you in eisy-ui so will have to look into it. Everything else seems to look ok, including the regular admin console.
October 24, 20251 yr Author 31 minutes ago, glarsen said:I too am using the latest beta UDM with eisy-ui 7.1 and everything looks good here. Unfortunately, I do see the same display as you in eisy-ui so will have to look into it. Everything else seems to look ok, including the regular admin console.7.01 or 7.1? I am using 7.01.Also can you check Sunrise and Sunset. Timedata seems ok but Sunrise and Sunset section blank in EISY-UI and shows the GV0, GV1 in UD Mobile after reboot. Edited October 24, 20251 yr by macjeff
October 29, 2025Oct 29 Solution @macjeff I think 3.4.0 fixes the issues on both UDM and eisy-ui. Remember to re-sync UDM after installing the latest update.Please let me know. Edited October 30, 2025Oct 30 by glarsen
October 30, 2025Oct 30 Author 14 hours ago, glarsen said:@macjeff I think 3.4.0 fixes the issues on both UDM and eisy-ui. Remember to re-sync UDM after installing the latest update.Please let me know.Yes the new version seems to have fixed it.
