October 25, 20251 yr I'm not sure if it is related to the 6.0.0 upgrade, but my Hue plugin is not longer operational. It finds the bridge, and detects that I have 4 devices, but they all fail to load.2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.1.31 4 bulbs found. Checking status and adding to ISY if necessary.2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.1.31 Found Extended Color Bulb: Garage smart plug(c62bbb770a285f)2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface.interface WARNING interface:db_getNodeDrivers: c62bbb770a285f not found in database.2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Exception in thread2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Thread-3 (parameter_handler)2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: :2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last):2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in bootstrapinner2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.run()2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 65, in parameter_handler2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.discover()2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 188, in discover2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._discover(idx)2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 222, in _discover2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.poly.addNode(HueEColorLight(self.poly, self.address, address, name, light['id'], light, hub_idx, parent_dev, zb_conn))2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 259, in init2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.updateInfo()2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 293, in updateInfo2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._updateInfo()2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 418, in _updateInfo2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: super()._updateInfo()2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 385, in _updateInfo2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: super()._updateInfo()2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 303, in _updateInfo2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.brightness = self.data['dimming']['brightness']2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: KeyError2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: :2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: 'dimming'2025-10-25 08:24:39.322 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
October 25, 20251 yr 16 minutes ago, x046866x said:I'm not sure if it is related to the 6.0.0 upgrade, but my Hue plugin is not longer operational. It finds the bridge, and detects that I have 4 devices, but they all fail to load.If you scroll through the top of this Hue part of the forum, there are related posts and things to try
October 25, 20251 yr Author I've tried all the basics. I've deleted the node, rebooted, and re-installed it. Still NG.I will continue poking through the forum. I saw there was a beta version, but not sure if that is more well suited to the newer bridge.
October 25, 20251 yr Author I deleted the PlugIn, restarted both ISY and Hue, re-installed the Plugin; same error. It seems to south just after discovery and I see the "db_getNodeDrivers:..... not found in database"2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.1.31 4 bulbs found. Checking status and adding to ISY if necessary. 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.1.31 Found Extended Color Bulb: Garage smart plug(c62bbb770a285f) 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface.interface WARNING interface:db_getNodeDrivers: c62bbb770a285f not found in database. 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Exception in thread 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Thread-3 (parameter_handler) 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: : 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in _bootstrap_inner 2025-10-25 09:56:29.204 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.run() 2025-10-25 09:56:29.204 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run 2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 65, in parameter_handler 2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.discover() 2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 188, in discover 2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._discover(idx) 2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 222, in _discover 2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.poly.addNode(HueEColorLight(self.poly, self.address, address, name, light['id'], light, hub_idx, parent_dev, zb_conn)) 2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^ 2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^ 2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
October 26, 20251 yr I do not know whether this is related to your issues, but I experienced a problem when the hue plug-in upgraded versions (I was already on IoX 6). Upon the plug-in upgrade, none of my existing hue nodes worked, but the upgrade process created duplicate nodes that did work. Unfortunately, I had to recreate all scene definitions and programs that were affected by the change in hue nodes and delete the old, non-functioning, nodes.One thing I can tell you is that the hue plugin appears to still work on IoX 6 for me.
October 31, 20251 yr Author Solution I just went in today and noticed there is an update. I updated the PlugIn and everything magically re-appeared. There is now a cost component, but if it will continue to work the price is acceptable.NOTE: I still see some of the same ugly error messages, but things appear to be working. Edited October 31, 20251 yr by x046866x
November 3, 20251 yr I upgraded to 6.0.0 Saturday and had not updated the HUE plugin so it must have upgraded with the 6.0.0 upgrade. I now have two devices like @oberkc for every device. Total of 73 (36 devices) so adding them back to all the scenes and programs is going to take a long time. :(I wonder if I could just restore my previous PG3x backup and it would fix it? I might try that first when I have time.
November 3, 20251 yr As I researched this more, I remembered that there is thread about a "Hue V2" plugin. I think the duplicate nodes are part of this new plugin. I further suspect that the new plugin became merged with the original when loaded to the store. When we were notified of an "upgrade", it loaded the new "V2" version. When I go to the plugin store, I notice that there is a 1.6 version (now a paid) and there is a 0.1.11 version. I suspect that we were on the 0.1.11 version when we got the upgrade notice. I wonder if going back and reinstalling the 0.1.11 version would bring ups back to the pre upgrade state. Unfortunately, I have already deleted my old nodes and recreated all my scenes and programs with the new nodes.
November 3, 20251 yr 2 hours ago, btreinders said: Total of 73 (36 devices) so adding them back to all the scenes and programs is going to take a long time. :(.In the programs you can use Find/Replace function which works well Scenes and resources though are a PIA
November 3, 20251 yr This discussion brings up a question: will the old 0.1.11 plugin remain available? For those of us who are fine with it and don't feel a need to upgrade?
