Hue plugin no longer operational
I'm not sure if it is related to the 6.0.0 upgrade, but my Hue plugin is not longer operational. It finds the bridge, and detects that I have 4 devices, but they all fail to load.
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface      INFO     hue:_discover: Hub 192.168.1.31 4 bulbs found. Checking status and adding to ISY if necessary.
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.1.31 Found Extended Color Bulb: Garage smart plug(c62bbb770a285f)
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface.interface WARNING interface:db_getNodeDrivers: c62bbb770a285f not found in database.
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Exception in thread
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Thread-3 (parameter_handler)
2025-10-25 08:24:37.934 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: :
2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in bootstrapinner
2025-10-25 08:24:37.935 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.run()
2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run
2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)
2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 65, in parameter_handler
2025-10-25 08:24:37.936 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.discover()
2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 188, in discover
2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._discover(idx)
2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/hue.py", line 222, in _discover
2025-10-25 08:24:37.937 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.poly.addNode(HueEColorLight(self.poly, self.address, address, name, light['id'], light, hub_idx, parent_dev, zb_conn))
2025-10-25 08:24:37.938 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.939 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.940 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.941 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.942 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.943 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.944 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 259, in init
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.updateInfo()
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 293, in updateInfo
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._updateInfo()
2025-10-25 08:24:37.945 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 418, in _updateInfo
2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: super()._updateInfo()
2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 385, in _updateInfo
2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_1/node_types.py", line 303, in _updateInfo
2025-10-25 08:24:37.946 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.brightness = self.data['dimming']['brightness']
2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ~
2025-10-25 08:24:37.947 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: KeyError
2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: :
2025-10-25 08:24:37.948 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: 'dimming'
2025-10-25 08:24:39.322 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
Solved by x046866x
If you scroll through the top of this Hue part of the forum, there are related posts and things to try
I've tried all the basics. I've deleted the node, rebooted, and re-installed it. Still NG.
I will continue poking through the forum. I saw there was a beta version, but not sure if that is more well suited to the newer bridge.
I deleted the PlugIn, restarted both ISY and Hue, re-installed the Plugin; same error. It seems to south just after discovery and I see the "db_getNodeDrivers:..... not found in database"
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      INFO     hue:_discover: Hub 192.168.1.31 4 bulbs found. Checking status and adding to ISY if necessary.
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      INFO     hue:_discover: Hub 192.168.1.31 Found Extended Color Bulb: Garage smart plug(c62bbb770a285f)
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface.interface WARNING  interface:db_getNodeDrivers: c62bbb770a285f not found in database.
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: Exception in thread
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: Thread-3 (parameter_handler)
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: :
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2025-10-25 09:56:29.203 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in _bootstrap_inner
2025-10-25 09:56:29.204 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: self.run()
2025-10-25 09:56:29.204 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run
2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 65, in parameter_handler
2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: self.discover()
2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 188, in discover
2025-10-25 09:56:29.205 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: self._discover(idx)
2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025fac_10/hue.py", line 222, in _discover
2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: self.poly.addNode(HueEColorLight(self.poly, self.address, address, name, light['id'], light, hub_idx, parent_dev, zb_conn))
2025-10-25 09:56:29.206 Thread-3 (parameter_handler) udi_interface      ERROR    udi_interface:write: ^
I do not know whether this is related to your issues, but I experienced a problem when the hue plug-in upgraded versions (I was already on IoX 6). Upon the plug-in upgrade, none of my existing hue nodes worked, but the upgrade process created duplicate nodes that did work. Unfortunately, I had to recreate all scene definitions and programs that were affected by the change in hue nodes and delete the old, non-functioning, nodes.
One thing I can tell you is that the hue plugin appears to still work on IoX 6 for me.
I just went in today and noticed there is an update. I updated the PlugIn and everything magically re-appeared. There is now a cost component, but if it will continue to work the price is acceptable.
NOTE: I still see some of the same ugly error messages, but things appear to be working.
Edited by x046866x
I upgraded to 6.0.0 Saturday and had not updated the HUE plugin so it must have upgraded with the 6.0.0 upgrade. I now have two devices like @oberkc for every device. Total of 73 (36 devices) so adding them back to all the scenes and programs is going to take a long time. :(
I wonder if I could just restore my previous PG3x backup and it would fix it? I might try that first when I have time.
As I researched this more, I remembered that there is thread about a "Hue V2" plugin. I think the duplicate nodes are part of this new plugin. I further suspect that the new plugin became merged with the original when loaded to the store. When we were notified of an "upgrade", it loaded the new "V2" version.
When I go to the plugin store, I notice that there is a 1.6 version (now a paid) and there is a 0.1.11 version. I suspect that we were on the 0.1.11 version when we got the upgrade notice. I wonder if going back and reinstalling the 0.1.11 version would bring ups back to the pre upgrade state. Unfortunately, I have already deleted my old nodes and recreated all my scenes and programs with the new nodes.
In the programs you can use Find/Replace function which works well
Scenes and resources though are a PIA
This discussion brings up a question: will the old 0.1.11 plugin remain available? For those of us who are fine with it and don't feel a need to upgrade?
