Unable to see nodes
I am trying to run Flair nodeserver on Eisy/PG3. I have client_id and client_secret from Flair app, but not sure of exact syntax to enter into PG3 configuration screen.
Can you provide some direction?
Maciek
@MBrzeski you need to add custom variables in the configuration screen.
From the More Info section:
"Add a custom variable named host containing the client_id and client_secret. Those value need to be requested from Flair Support."
Click on "Add Custom Parameter" and then the "Key" should be "client_id" and add another to be "client_secret". Then hit save changes and restart the plugin.
Be sure you are not logged into Admin Console at the same time as installing/updating plugins. When admin console relaunches it will read/load any changes you made in the plugins.
  • 4 weeks later...
Thanks for the reply.
I checked with Flair support and the credentials are now provided directly in the IOS app, which is what I have been using. Are there any delimiters required around the parameters (such as "SKJFKFKJFBEKFJ" or 'KSDFJFBSDFKJBFSDKJ') or just enter the raw parameter?
OK. Thanks for your help. I think that this may be an OAuth 1.0 vs 2.0 issue. Flair has moved their authentication to OAuth 2.0 and I suspect the nodeserver is still using OAuth 1.0. I don't know much about OAuth, just trying to get my vents working!
