November 12Nov 12 I installed the Yolink plugin and configured the UAID and secret key. I currently have a vibration sensor and a weatherproof temperature sensor (set up for testing). The nodes came up fine, and the status display for each device appears to be correct. But I'm trying programs and things aren't working as I would have thought. I created two test programs, one for each device.1- I created a test program for the vibration sensor (configured as a DON/DOF device), first to detect a control event:yolink vibration test - [ID 00BF][Parent 0001]If'Vibration Sensor' is switched Vibration DetectedOr $s_yolink_trigger > 0Then$s_yolink_vibration += 1The "Or s_yolink_trigger > 0" statement is just to test that the program is running ok and that the variable display in admin console is updating in realtime. The sensor detects vibration ok (LED blinks), and triggers a Alexa message that I set up in the Alexa app, but the s_yolink_vibration variable doesn't increment. As if the plugin wasn't seeing it. Even if I wait 10 minutes or more for the time to go beyond the "last poll time" in the Yolink Setup node (shows as online and ready).I then modified the program to look for a status change instead.yolink vibration test - [ID 00BF][Parent 0001]If'Vibration Sensor' Vibration State is No VibrationOr $s_yolink_trigger > 0Then$s_yolink_vibration += 1The first quirk is that no matter if I choose "Vibration" or "No Vibration" for the Vibration State status and click on update, the program line always shows "No Vibration" as above. There are also two "Vibration State" statuses to choose from in the list, but both only show "No Vibration" when you update the line. Ok, so I tried making it "if is not No Vibration" a double negative... But no matter what I try, the variable never increments.2- I thought I'd then try the temperature sensor. Created the following test program:yolink temperature test - [ID 00C0][Parent 0001]If'Temperature Sensor' Sensor Temperature > Updating (may take up to 1 hour)Or $s_yolink_trigger > 0Then$s_yolink_hightemp += 1The first quirk is that in the program editor, what I actually entered is if the temperature is > 26, but the program always shows as "Sensor Temperature > Updating (may take up to 1 hour)". I can't get it to display the temperature value I programmed, though it seems to save it correctly because if I go back to the program editor, the value I entered is still there in the bottom part of the screen. So I have no idea what IoX is seeing. But the program doesn't detect the temperature going over 26 C, even though I do see it update correctly if I view the temperature sensor device node directly.So the device nodes seem to be working, but not when referenced in programs.Another quirk is if I edit the node names and reboot the controller, the default names come back.I'm testing this with IoX 6.0.0 Edited November 12Nov 12 by Guy Lavoie
November 12Nov 12 Can you enable debug in the log and do a few actions and PM me the log - I can take a lookIt does appear something has changed in 6.0 with how AC works with temperatures - I am still battling this - I do see the same issue I think it is related to having multiple definitions for editors - I have one for unknown and one for actual data - I believe there are some tickets already filedIn general, I recommend using the alarms in yolink sensors, but getting the status should work as well
November 12Nov 12 Author Ok, I'll try and do that either later this evening, or tomorrow.6.0.0 does seem to have affected some plugins, as we've seen on the forum.
November 13Nov 13 Author I created another test today: copying the temperature (of the temperature sensor) to a variable. I triggered it with the s_yolink_trigger variable as shown in my programs above. The value was correctly copied into the variable.
November 14Nov 14 @Guy Lavoie Hi Guy, this is my program to monitor my current pool temperature:Pool Temp - [ID 00B1][Parent 0094]If 'Nodes / YoLink / Temp Pool' Sensor Temperature > 0.0°FThen $sPoolTemp = 'Nodes / YoLink / Temp Pool' Sensor Temperature °FElse - No Actions - (To add one, press 'Action')I don't know that your High Temp program works as the temperature might not go up exactly 1 degree (maybe more, maybe less). I posted elsewhere (and can repost here if you want) what conditions are required for a YoLink sensor to update. No matter what, it updates each hour. You may need another program to set the High Temp variable only if the Current Temp is > than the High Temp.Ross
November 14Nov 14 Author Yes, that's how I typically capture a value from a sensor into a variable, by running a test that's always true. I'm not planning on using the high/low limit values or event triggers from the temperature sensor. That s_yolink_high_temp variable was just for testing purposes, to increment that variable by 1 every time the sensor temperature went over 26 C (I'd trigger it by holding the probe in my hand). The second way that would work here is by capturing the value in a variable and then testing against that, as I indicated in my later post.My intended use is for two things: First is to be able to ask Alexa what the pool water temperature is. This works, directly with the yolink's Alex skill (the connection to eisy isn't even needed). The second use will be to update my solar pool heating setup by capturing the water temperature to a variable, and also the temperature in the enclosure where my solar heating coils are on the roof with a second temperature sensor (I have 1200' of hose, in glass covered enclosures). Currently what I have up there is just a mechanical on/off thermostat, giving me a contact closure when it's above 80 F. In my updated version, I want to compare the water temperature against the enclosure temperature, ideally the water temperature where it exits the enclosure, and turn the valve to activate the solar heat when the water up in the enclosure exceeds the pool temperature by a certain margin.
8 hours ago8 hr Author On 11/12/2025 at 5:05 PM, Panda88 said:Can you enable debug in the log and do a few actions and PM me the log - I can take a lookIt does appear something has changed in 6.0 with how AC works with temperatures - I am still battling this - I do see the same issueI think it is related to having multiple definitions for editors - I have one for unknown and one for actual data -I believe there are some tickets already filedIn general, I recommend using the alarms in yolink sensors, but getting the status should work as wellJust wondering if you made anything of the logs I sent you.
6 hours ago6 hr files look ok - there is some issue with how 6.0 uses the inputs from PG3x - I have a ticket with udi, but no reply yet
