Intermittent delay on motion detection in plugin
Hi @Panda88,
I know you are busy working the rest of the kinks out, and I really appreciate your dedication!
The following is definitely not an emergency situation but it is something I would like to fix eventually.
Since I switched from the stock hub to the local hub I have noticed that sometimes there is a delay from the time motion is detected to when the plugin reports it. It varies. Anywhere from a few seconds to maybe 20 seconds at worst. This began with your first non-production plugin and has continued thru to yesterdays updated production plugin
Same set up with same number of temp sensors, switches and water leak sensors. Never experienced it at all with the old hub. Started with the new hub and new plugin.
I was able to finally figure out that the Yolink app received the motion detected signal almost immediately but sometimes that delay occurs for the plugin to detect.
It is so random that I don't even know how to go about troubleshooting any further. I think my next step is to pull one of the motion detectors and put it at my bench for further testing.
Finally, to my question, what would you recommend I do or test for when I do this.
Thanks again,
_Tim
