Insteon Controller Scheduling
I am on a Polisy Controller 5.9.1 and using version 1.4.3 on the UD Mobile App. The Insteon controller I am trying to schedule shows up on Apps Home Tab and Favorites tab, but when I go to My Schedules under the Automations tab, I do not see the Insteon controller that I simply want to schedule on-off hours, but I can control it manually from the app. What am I missing? Yes, I have tried re-syncing 3 times.
Solved by Geddy
@FloridaGary I am not sure how much programming has advanced on UD Mobile, but it didn't used to be all that easy. Simple solution would be to use admin console to make a program. Maybe post your screen shots that you see.
Have you attempted to add/make a new program? Look at the "My Programs" under Automations then click the "+" on top right. Should give you the option for "New Program". It takes a while to spin and then comes up with the program appearance. Add you conditions (Time shows "error" until you make a selection). The "THEN" action will be "Command". Here you select your device and what you want it to do.
After you complete it be sure to "Save" (top right). Then go back to main screen and sync (just to be sure it's written to the Polisy IoX). I think "My Schedules" would work the same, but I went down the "My Programs" side just now.
@Geddy Thank you. Your guidance helped me set up a new schedule within the mobile app. By 10pm Eastern tonight, I’ll know if it worked. Thanks again for your help. Much appreciated.
