Which elements in programs need update?
I found the below info (bolded text by me) in the github docs page on the latest update to Timedata. Can someone clarify which "certain elements" may need to be updated? Timedata is used throughout many of my programs but I don't know what to hunt down and update. I did see the post below where were referencing sunrise/sunset values, but wasn't sure if there were other things to be on the lookout for.
3.4.0 28/102/2025
  • minor code and profile changes to fix a problem with data not showing properly in eisy-ui
  • the changes may require that certain elements in IoX programs be updated.
Solved by glarsen
I believe that the only elements affected were the sunset/sunrise node drivers.
