Eisy time ?
After the newest upgrade my eisy is running progra.s one hour behind. When I checked the last run times it shows an it ran on the time it was supposed to . So I think it time clock is an hour off . How can I fix this?
As @paulbates it might fix itself after a day, but more than likely it needs a full power cycle (Press and hold the power button if you see the light turn red release, allow a few seconds then press and light should turn blue when powering up). This would allow the device to update and to poll the time server to get the proper time. Is your location set to a custom location or a pre-defined time zone in the pull down in the configuration tab?
Be sure to check that your "Timezone Offset" is correct.
Are you running any firewalls, VPNs, or VLANs that might be blocking IoX communication to the WAN?
