Trouble connecting Eisy to Elk m1xep
The PG3 is stuck at ELK Connection started... Config info will update when complete.
You need to add the non secure port to the IP address, as per the instructions:
"Set host to the host or ip address and port, e.g. 192.168.1.15:2101"
The non secure port is 2101. In addition make sure Elk M1XEP is not set for "secure port".
Remember, only one connection can be made to Elk at a time. Therefore, you can not be in ElkRP2 while trying to connect with the plugin.
Thanks for your reply
My secure port is set to 2601. Should it be blank?
You must use non secure port as shown in the plugin instructions. The plugin will not work with the secure port.
You also need to follow the example in the instructions for adding the port at the end of the IP address, :2101.
