.yaml file location
Hi @sjenkins ,
I want to provide the configuration via a .yaml file but I'm not sure where to locate it on eisy so the plugin can find it. Looking through other threads, I saw this path mentioned:
/var/polyglot/pg3/ns/<specific plugin directory>
When I try to open that directory permission is denied. I tried stopping the plugin and using 'sudo', but I can't get access.
If that is the correct location, how to I add the .yaml file?
Thank you.
Solved by jkmcfadden
# Store in /usr/home/admin/
# No SSH required, Command to copy file FROM cd current directory (e.g., Mac desktop) to eisy
# Replace with your own IP and user name and dev file name
scp 2025-10-10-devfile.yaml admin@10.20.30.xxx:/usr/home/admin/
