Variables not syncing name
I have recently added some state variables. After syncing UD mobile, the variables show up, but are listed by number, not the name I gave them in isy when I created them.
I just discovered the same issue on trying to setup new UD Mobile install on the Android OS. Everything claimed to sync, but discovered this on setting up the first favorite. If I discover any reasons for this I will post or eagerly wait experts response.
It's happening to me also but only for recently added variables (created within the last 2 weeks on version 6.0.3) - now on 6.0.4.
@Mr B @ISY4Me
Yes, this is what I am experiencing. I also have noticed that doing a sync is nothing like it used to be. It is taking very little time, not going through anywhere near all the flashing names of stuff that it used to, and when it "finishes" it isn't giving me the usual finished screen with the option to delete unused values.
Yes, however there is now a several seconds long delay where the screen stays blank when you first fire up the app and when your device list appears, device statuses are already updated. Sounds like there is a silent sync of the displayed devices during that blank time. Not a bad idea really if that's the intent.
@Guy Lavoie I think you are referring to status update. I am speaking of syncing the devices themselves (adding/removing/etc), not their current status.
But in my case, I'm not noticing any difference in status populating upon opening. When I open the app, things populate like popcorn, sorting of randomly about.
I've also noticed that, though I've only done it once or twice since that change
@apostolakisl I was examining this “Variable Names Showing as Number” issue and when I went to my monitor attached to the EISY box and looked at the Variables List to get the Variable ID for the parameter I was looking for to add a panel to my favorites.
I noticed that in some cases the Android UDM did not pull the same variable data that showed when I looked at the variable list directly on the EISY box.
Did you observe the same thing? Variable ID comparing UDM Android to EISY Variable ID, some data agreed and some did not.
Update. I noticed the next day that some of the variables which were not consistent with the actual data on the EISY box were now updated and were showing the same value as the EISY. This was not an issue of waiting a few hours, but roughly 24 hours. Not sure about this... is there some sync or data update on a timer? No idea, but as of today, all the variables I have added to the favorites tab are the same as the raw data on the EISY Box.
Edited by ISY4Me
Update...
