ISY is not online - Admin Console-Portal Tab blank
Need a "How-To"
Admin Console 6.0.4 - Portal Tab: (pop-up window): Portal Settings/Account Management has been moved to eisy UI: https://eisy.local/settings/portal
Unable to connect to this URL, so I can allow internet connection. https://IP doesn't work
Background:
A couple days ago, I Installed a second eisy (eisy-2) in my UD Portal account and it is currently running as the lighting controller.
Original (eisy-1) Admin Console: UI and Firmware 5.8.4 is now without a PLM (needs to be flashed to update the UI & Firmware)
Newly installed (eisy-2) has latest upgrade lox UI and firmware 6.0.4 with NVMe SDD with PLM.
eisy-1: Admin Console Portal Tab - registered/online & UD Mobile Device
eisy-2: Admin Console Portal Tab is blank (pop-up) so it is not registered & UD-Account Connection message: ISY is not online.
Both have a current Portal access License.
eisy-2: Admin Console Portal Tab: (pop-up window): Portal Settings/Account Management has been moved to eisy UI: https://eisy.local/settings/portal
Unable to connect to this URL. Tried all I can think of (Fire Wall, IP, router settings.....
Both eisy's have a registered router IP in DHCP ISY Https Port 8443.
Looked at the eisy-2 log but no errors.
What next?
@m6bigdog this sounds like could be a browser issue. If you're able to log into the eisy just using "eisy.local", but you're unable to browse to the settings/portal page or it's blank I would think it is browser related.
Have you tried a different browser? Or depending on what you're using try a private or incognito browser session to see if plugins or cache might be blocking/hiding the information.
Since this is a new setup and you've not been able to get it registered with the portal I would suggest opening a support ticket with UD so they can explore the issue and make sure this isn't a system issue with eisy-ui and hopefully get you up and running quickly if they find the problem.
Support tickets can be opened here: https://www.universal-devices.com/my-tickets
Either way, please post back what steps they go through to get this resolved so it might be able to help others should they face a similar issue.
I use lox finder with registered IP to log on to the Admin Consoles.
command prompt: I can ssh admin@IP-address.
Wait, Wait.... I just clicked on the Portal Tab window, "https://eisy.local/settings/portal",
Hint the mouse Pointer went from an arrow to a hang.
A Page opened and I was able to sign in & approve.
Problem solved
